Airconditioning Air diffusers | FerrariChat
Discussion in '308/328' started by NJMatt, Oct 3, 2025.
  1. NJMatt
    NJMatt Rookie
    45
    New Jersey
    On my 308QV the air-conditioning air diffusers at the bottom of the dash have a weird wire mesh installed in place of fins. I'm replacing them with diffusers that have the fins. My question is; there are 2 vertical knurled rings, one on each side of the fins. The part is symmetrical and can be installed 2 ways. According to the diagram in the manual the left ring controls the horizontal fins and the right ring controls the flow. Is this the correct orientation? Are they both the same or mirrored?
    A fine point but the manual is instructions for use and not assembly, I just want to be sure. If i'm going to install them might as well be the same as the factory.
    Thank you.
  2. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,304
    Black Forest Germany
    Martin N.
    They are the same, but you install them mirrored.
    BTW. The first thing I did to my first Iphone, was switching that annoying native Apple picture format from HEIC to jpg, so that future pictures are automatically saved in jpg. In your post, you see why.
    Best from Germany
    Martin
  3. NJMatt
    NJMatt Rookie
    45
    New Jersey
    Thank you for the advice.
    Yes I was lazy and did not change the picture format this time.
