Aircraft guru's... | FerrariChat
Aircraft guru's...
Discussion in 'Other Off Topic Forum' started by F40, Nov 7, 2004.
  1. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    Possible, but maybe unlikely. Semenatics - Cruise never "flew" any F14.
    All F14's are 100 series. There may have been some stock footage of 104 spliced into the movie, like some of the formation flying or carrier launches.
    Most of the scenes were really models, so the model may have the same "bunu" (bulkhead number) as a real F14. There were very few scenes of real planes, believe it or not. Though I believe Cruise did get an incentive ride in a real F14. "Just don't touch any of the buttons, Tom."
  2. ralfabco
    ralfabco Two Time F1 World Champ
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    There are also 200 series F-14's. Remember most of the time there are, or were 2 squadrons deployed on the boat. Nowadays they might have changed the sq's by also putting some F-18E's, to deploy along with the F-14's. The # of F-14's in the Sq may have also been changed from the Cold War era.
    The only way to know; is to look at the USN serial # on the F-14 just below the elevator. An example of the number would be 161512 or 159818. Those are the only #'s that always stay with the airplane.
  3. Ferrari0324
    Ferrari0324 F1 Rookie
    Mar 20, 2004
    3,510
    Brandon
    If I remember correctly a teacher of mine in tenth grade told us an old student of his (like from the early 80's) was a fighter pilot and actually did the flying and fighting scenes for Top Gun. I vaguely remember a teacher saying this.
  4. cab7104
    cab7104 Karting
    Mar 25, 2004
    237
    Rochester, NY
    Craig
    From what I understand, the US Navy was very against helping the producers/directors of Top Gun. I believe that all that the Navy gave them were two "dummy" test range missiles. I have watched several interviews( there might even be one on the dvd, I can't remember) where the directors said that they did all the flying stuff with models, ranging from 1/86 up to I think 1/8 scale(pretty big model!!). It may be a plane that was used in stocck footage that may have been used, however I would say it't the same number, but not the same plane.
    Craig
  5. lionsfan54
    lionsfan54 Karting
    Nov 7, 2003
    114
    Pretty sure Cruise flew an A model (needed burner on takeoff)
  6. coolestkidever
    coolestkidever F1 Veteran
    Feb 28, 2004
    5,538
    NJ
    Patrick
    one of my neighbors when i lived in La jolla california was an instructor at Miramar. not really realted but it was pretty cool.
  7. GoFerrari28
    GoFerrari28 Formula 3
    Jun 16, 2004
    2,313
    Ridgemont, CA
    Jeff Spicoli
    The plane in the picture appears to be an F-14 D, since the under-nose cluster appears to include both the TV camera and an IR sensor, the retractable canard in the leading edge of the wing glove has been deleted, and the ejection seats are the newer NACES II system rather than the old Martin-Baker Back Breaker. Every air wing up until 1996 had 2 Tomcat squadrons, with either a modex and codex of 1XX or 2XX, so 104 was common. From the looks of the helmets the stick and RIO are wearing, the helmets are the newer, low drag jobs and appear to be done in the colors of VF-2 Bounty Hunters, which, while they were partnered up with VF-1 Wolfpack, had 2XX modex and codex, but after VF-1 was decommissioned in '94, left VF-2 to take the 1XX modex and codex. The block numbers are under the horizontal stab, at the end of the Navy Bureau number for the airframe, to denote hte construction block of airframes that the aircraft was built in.
  8. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
