Airplane physics question | Page 93 | FerrariChat
Discussion in 'Other Off Topic Forum' started by alanhenson, Dec 3, 2005.
Does the plane fly?
  1. Yes
  2. No
  3. Question doesn't allow answer.
Multiple votes are allowed.
Results are only viewable after voting.
  1. Zack
    Zack Formula 3
    Dec 18, 2003
    2,003
    Nicosia, Cyprus/Cali
    Zacharias
    Depending on the coefficient of friction, and the power produced by the engine, of course the plane could skid. The issue is not whether it could. It's just not the situation that is being posed in the question, so why bring it up?
  2. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,522
    SFPD
    Dirty Harry
    Ah, but could conveyer belt counter-skid?
    via rubber ducky
  3. Zack
    Zack Formula 3
    Dec 18, 2003
    2,003
    Zacharias
    And if it's wearing underwear, would the skid marks show?
  4. Zack
    Zack Formula 3
    Dec 18, 2003
    2,003
    Zacharias
  5. Zack
    Zack Formula 3
    Dec 18, 2003
    2,003
    Zacharias
    In a hurricane.
  6. Zack
    Zack Formula 3
    Dec 18, 2003
    2,003
    Zacharias
    At night.
  7. wax
    Jul 20, 2003
    52,522
    SFPD
    Dirty Harry
    No wind . . .
    via rubber ducky
  8. Zack
    Zack Formula 3
    Dec 18, 2003
    2,003
    Zacharias
    Yup yup. No wind if you are moving at the speed of the hurricane. In the hurricane. On Mars. At night.
    Ducky seems dubious. Is it the, um, rubber?
  9. wax
    Jul 20, 2003
    52,522
    SFPD
    Dirty Harry
    #2309 wax, Nov 18, 2012
  10. chp
    chp Formula Junior
    Jul 9, 2005
    372
    Will ducky fly if put on a conveyor belt?
  11. wax
    Jul 20, 2003
    52,522
    SFPD
    Dirty Harry
    #2311 wax, Nov 18, 2012
  12. chp
    chp Formula Junior
    Jul 9, 2005
    372
    :D
  13. zoowho2
    zoowho2 Formula Junior
    Oct 29, 2012
    269
    Arizona, USA
    Tom
    A VERTOL or jumpjet would be able to ascend............
  14. drjohngober
    drjohngober Formula 3
    Jul 23, 2006
    2,040
    Cville and Gbury Tex
    Dr.John Gober
    Ok. Somewhere between we just can't let this thread die and beating a dead horse, I had this one additional thought while walking through PHL this weekend.
    While walking on the horizontal people movers ( escalator but flat) what if a person turned around and walked in the opposite direction of the motion of the conveyor. At exactly the same speed at any point in time in the opposite direction of the conveyor belt.
    Would there be any movement of the person realative to fixed ground?
  15. Zack
    Zack Formula 3
    Dec 18, 2003
    2,003
    Zacharias
    Too many variables! Is the earth rotating and are you doing somersaults or cartwheels and did you have beans for lunch...?!
    Also, are you attached to an airplane?
    If so, how long have you had these feelings?
  16. tonyhemet
    tonyhemet Karting
    Jul 21, 2012
    199
    hemet,ca,usa
    anthony gonzalez
    If this is a question about an airplane,,
    Why are we using seafaring phrases ?
    Flogging and such.
  17. drjohngober
    Jul 23, 2006
    2,040
    Dr.John Gober
    Final video proof.
    Start 2:45
    [ame]http://www.youtube.com/watch?v=Temm5lI-zUI[/ame]
    If conveyor belt theory worked, plane could take off without pick up truck moving forward.
    Game
    Set
    Match
    Merry Christmas
  18. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    You're describing a treadmill.
    All this proves is that the plane doesn't need wheels to fly.
    This one is interesting as well.
    [ame]http://www.youtube.com/watch?v=KqryALqiQW0&feature=share[/ame]
  19. boatr2001
    boatr2001 Karting
    Oct 3, 2006
    88
    Rockford,IL
    #2319 boatr2001, Dec 24, 2012
    17,000 hour airline pilot. Wheel speed has got nothing to do with it. Aircraft take off and land into the wind to REDUCE distance requirements. The boeings I fly have max wheel speeds around 195kts....We rarely get close to that- with the exception of an emergency configuration that would require higher approach speeds, there is one scenario which I think closely resembles the OP question about tire/wheel speed.....In a high density altitude takeoff -think Mexico city 100f- care must be taken to avoid exceeding 195kts on the tires. The aircraft only cares about the air it lives in-for producing power and relative wind over the wings.
    Assume still air. The aircraft will fly at the same indicated speeds. However, at a very high density altitude, an indicated rotation speed of say 140 kts, may actually be a true airspeed of about 175-180.The wheels are spinning at 175-180kts. Go higher or hotter and wheel speed can go off the charts. The aircraft will continue to accelerate forward because the engines and wings could not care less the rate of speed of ground passing beneath.
    So in the original OP's question, the wheel speed may exceed 50,000 rpm- doesn't matter. The airplanes gonna accelerate and fly- wheel/tire friction is negligable.
  20. Zack
    Zack Formula 3
    Dec 18, 2003
    2,003
    Zacharias
    Yes, of course the plane flies in real life.
    No, of course the plane would not fly if the other condition is being met, that the wheels are not moving forward ie. the plane is sitting still on the conveyor belt.
    We all know that both conditions cannot coexist ie. plane moves forward and plane sits still.
    The question describes two situations which cannot possibly coexist:
    1. Engines producing thrust, AND
    2. Wheel speeds matching treadmill speed.
    If one is true, the other HAS to be false.
    Stupid effing question.
  21. vincent355
    vincent355 F1 Veteran
    6,540
    Wine Country
    Vincent
    Yes or no
  22. Zack
    Zack Formula 3
    Dec 18, 2003
    2,003
    Zacharias
    You forgot to give me the third option!
    ROFLcopter!
  23. vincent355
    6,540
    Wine Country
    Vincent
    #2323
    Why do you think that is...reason???
    I think not, nor do you.
    Play along
  24. Zack
    Zack Formula 3
    Dec 18, 2003
    2,003
    Zacharias
    Two of the hugest myths in history:
    I think therefore I am.
    There is no such thing as a stupid question.
    And, of course, Humpty Dumpty was pushed. We all know that.
    Playing, player. Your turn. :)
  25. wax
    Jul 20, 2003
    52,522
    SFPD
    Dirty Harry
    IIRC, Humpty Dumpty was poached.
    via rubber ducky
