Alarm battery upgrade on 360 - killing the red dash LED :-) | Page 10 | FerrariChat
Discussion in '360/430' started by RayJohns, Jul 2, 2006.
  1. captglen
    captglen Formula 3
    1,790
    West Palm Beach, Fl
    Glenn L.
    I installed a GM Siren and it works perfectly, chirps and red light
  2. wong360
    wong360 Rookie
    Mar 14, 2015
    31
    Hi Glen,
    Big fan of your exhaust systems- hope to be an owner soon!
    Does your siren sound off when the alarm is activated?! Mine doesn't.
  3. rmarchjr
    rmarchjr Formula Junior
    May 21, 2012
    586
    North east, USA
    Most of the things I do to my Ferrari's are also for my satisfaction not cost. Driving them is awesome but it is almost as satisfying to fix them.
    thanks for taking the time to write it up
  4. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    I assume the ferrari replacement unit is a simple swap out.?
  5. vrsurgeon
    vrsurgeon F1 World Champ
    16,571
    Charleston, SC
    Curt
    Plug and play. Take off panel, unplug, remove, replace and plug in.
  6. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    I think the GM replacement is just as simple, no? $369+ frieght for the F unit on Ricambi now, $85 including freight for the GM Bosch unit - Genuine ALARM (15213135) for Your GM Vehicle
  7. vrsurgeon
    16,571
    Charleston, SC
    Curt
    GM unit is just as simple. I've been using it in mine for 4 years. Some differences with the alarm reported.. but I don't care. Alarm does squat besides annoy people. If you want protection, get a GPS locator :)
    Also try used GM parts suppliers. I bought my GM alarm on ebay for 20 bucks! Of course.. I was the one that discovered it. :)
  8. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    Agree 100%!!
  9. 993man
    993man Formula Junior
    878
    New Zealand
    Graham
    I got tired of the red light, so I just bought a new siren from Ricambi and threw it in.
    No more red light. It's not worth mucking around with IMO
    Mind you, I did try the "connect this 9 volt battery in trick", but that was an epic fail!
  10. captglen
    captglen Formula 3
    1,790
    West Palm Beach, Fl
    Glenn L.
    Hi Wong,
    Sorry for the late reply.
    Last time I checked it did go off when I triggered it
    I Look forward to hearing from you when you are ready
    Regards
    Glenn
  11. geoffpfc
    geoffpfc Rookie
    Aug 15, 2013
    19
    Hampshire England
    Geoff
    Thanks for all the useful information guys - when my red light came on I went straight to this forum and followed the advice not to wait too long before taking action, so I went straight out removed the siren, I had to use the wife's hair-dryer to soften the glue on the membrane, unfortunately I don't live in sunny California, before I could ease it enough to start the cutting, it was useful to have a helping hand so that I managed not to cut myself.
    The 2 Varta batteries had just started to leak, but had not caused any damage, apart from some marking of the PCB, which cleaned up and was sealed with PCB lacquer.
    I went for the remote battery option and sourced the identical Varta battery, but in a 6 cell configuration - I like to keep things original where I can.
    All works fine, no red light and siren sounds - brilliant - that's saved me £260 ($390) and it's easy to change the battery as it's now under the cover plate for the master cylinder.
    Once again many thanks to Ray Johns
  12. Chrisnlbc
    Chrisnlbc Formula Junior
    Jan 9, 2015
    374
    Huntington Beach
    Just got done replacing mine with the GM replacement part # 15213135.
    My siren has never worked since I bought my car. Followed the walk thrus, plugged this new GM one in, no more red light. Chirping works great. Seems like new again!
    My car is a 2004 360 Spider, US F1. Hope this helps everyone else and save yourself $400 bucks.
  13. Chrisnlbc
    Jan 9, 2015
    374
    Huntington Beach
    Just a little follow up also. I opened up my old siren to see if it was salvageable. Not so much! In the garbage it goes! Fried Board :(
  14. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    My GM alarm arrived today, hope to put it in on Sunday!
  15. captglen
    captglen Formula 3
    1,790
    West Palm Beach, Fl
    Glenn L.
    Yup, It seems they will all leak eventually
    My board looked like yours
  16. Chrisnlbc
    Jan 9, 2015
    374
    Huntington Beach
    Yea it was in bad shape. Thanks also Glenn for the cupholder. Got it installed last week. Looks great..
    Chris
  17. supratime
    supratime Formula Junior
    Mar 22, 2006
    597
    Having trouble finding the correct 9v terminal connector .. Will this work?
    http://pages.ebay.com/link/?nav=item.view&alt=web&id=301506311561&globalID=EBAY-US
    They are 8 inches long, so I if need to be longer I will solder two together to make it long enough .. I'm worried about diode or resistor built in as stated above ^ and will not charge the v9 battery.. Also The wire looks correct 22awg?
    Or can anyone refer a link for the correct 9v connector?? Thx in advance
  18. Skidkid
    Skidkid F1 Veteran
    9,591
    Campbell, CA
    John Zornes
    Most any one will work. You can even get them at Radio Shack
  19. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Except you'd have to go back in time to when Radio Shack stores still existed!
  20. supratime
    Mar 22, 2006
    597
    Yup!! Decide to go RadioShack and everything worked!! Red Light gone and all functions work on the alarm!! Big thx to the OP + everyone else for this awesome thread!! Woo woo
    cheers!
  21. supratime
    Mar 22, 2006
    597
    I thought this too.. Found one only 5 miles away :) they apparently now general wireless operations dba as RadioShack.. Going for a comeback!
  22. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Good to know, thanks!
  23. William Tell
    William Tell Karting
    Sep 2, 2014
    189
    Switzerland
    Villi
    One thought. Why fix it?
    Does it matter if the light goes off or stays on?
    My car runs perfectly regardless of the light not working.
  24. supratime
    Mar 22, 2006
    597
    I totally agree! Just got bored one day and decided to give it a try. I think it's the idea of being proactive. If you attack the issue early you can potentially save yourself a few bucks down the line. That's if you even care about this insignificant issue. Doesn't really need to be fixed IMO..
    Tried fixing it yesterday but the red light still goes on under 2 conditions.. (when started and has recently been driven.) BUT after stitting for a while (hr or two), it it all seems to work again from initial start up ( with no red light). But this just after 2 days of analysis.. so who knows what it will do later on lol...
    I'll live with it.. the red light reminds me to slow down when driving too fast lol and I don't need the Chirps.. Everything else works 100% fine like u said so why bother??? End of the day problem can be fixed with a GM module for 70-80 bucks
  25. supratime
    Mar 22, 2006
    597
    Update: (if anyone still cares) went back and cleaned the circuit board more thoroughly with Q-tips/rubbing alcohol. Inside out and dried with low heat hair dryer...after multiple drives, everything seems good to go... at cold, warm or hot! The alarm, lock, unlock, siren, chirps all work like it should! And no more red light.. More important than the battery is cleaning that board like brand new again... given your board is not already toast.. Simple.. But I overlooked it..Cheers
