Alarm battery upgrade on 360 - killing the red dash LED :-) | Page 9 | FerrariChat
Discussion in '360/430' started by RayJohns, Jul 2, 2006.
  1. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    The boards that use the two round batteries about 20 mm diameter and about 10 mm thick seem to have fewer problems with upgrades than the boards with the stand-up computer M-B style batteries.
    It's always a crap shoot.
    However, that board is very polarity sensitive. So if you even briefly touched an wrong polarity you toast the board
  2. wahoowa
    wahoowa F1 World Champ
    11,246
    _East Coast_
    Bill
    Another data point: 15213135 was $115, an independent sourced it for me, it's installed and chirps correctly for lock/unlock.
  3. Randy B
    Randy B Karting
    Jun 7, 2013
    69
    Didsbury AB,Canada
    WTH?? Went to pull the car out to give it a wash and now the alarm works just as it should. Beeps for locking/unlocking and the alarm goes off, no red light on the dash. Haven't changed anything else since yesterday and car sat through the night with the disconnect turned on. Not complaining here but I would like to know what changed and what exactly solved my problem.
  4. bikz
    bikz Formula 3
    Mar 2, 2012
    1,043
    Malaysia
    #204 bikz, Sep 11, 2014
    sorry guys if this has already been asked but can i unplug the siren without having to cut the battery / turn off the master switch? will there be any issues?
    can i use the car with the siren unplugged? will it affect the alarm ecu?
  5. Jamarico
    Jamarico Karting
    Nov 30, 2012
    144
    Switzerland
    Marco
    Yes, you can unplug the siren without having turn off the battery switch.
    And yes, you can use the car with unplugged siren, red LED will be on permanently.
    There is no issue with the Alarm ECu at my car....
  6. bikz
    bikz Formula 3
    Mar 2, 2012
    1,043
    Malaysia
    thanks....any particular reason why everyone who performs this (removing the siren) kills of the car's master switch/batteries? then there is the whole process of switching turning on the batteries and making the car relearn its parameters right?
  7. tomconte
    tomconte Formula Junior
    May 15, 2010
    385
    Atlanta
    Tom Conte
    I need some help on this: I did the GM part replacement.
    My siren sounds, which is great.
    Now the not great: it also sounds when I disconnect the car battery! So I can't use the cutoff switch without waking the neighbors and making my dogs bark.
    Anyone else had this happen to them?
  8. Randy B
    Randy B Karting
    Jun 7, 2013
    69
    Didsbury AB,Canada
    Yes I have. Also used the GM part and didn't discover this until I went to put the car away for the winter. Car locked, front hood open and turning the disconnect off triggers the alarm. Had to leave the disconnect on and battery tender plugged in.
  9. tomconte
    May 15, 2010
    385
    Atlanta
    Tom Conte
    Ugg. Thought about putting a cutoff switch on the harness and then it hit me...there's no power. Duh.
    GM service manuals probably have something on how to turn this off.
    In a boring all-day meeting, so I guess I'll google around.
  10. tomconte
    May 15, 2010
    385
    Atlanta
    Tom Conte
    Ok so I found one suggestion, but I do not know if this works.
    I'm on the road and won't be able to test this for a few days.
    In any regard, here's what I found:
    1) hit immobilizer button
    2) insert ignition key & turn to second position (not all the way to ignition)
    3) rotate the key back to zero, but do not remove the key
    4) then disconnect the battery
    alarm should not sound
    Anyone want to try it?
  11. tazandjan
    39,316
    Tom- The siren is hot-wired around the cut-off switch, so that is what you are probably getting and the Vette siren may be wired a little differently. Designed so someone could not drain the battery (C4 Corvettes were stolen that way) and make the alarm inop.
    Why do you want to use the battery disconnect switch that often, at any rate? That is largely for your techs and not really for frequent use. Put a battery maintainer on her instead of using the disconnect switch. Everything will be happier. Also, one of those small computer memory savers with a 9 volt battery that fits in the cigarette lighter might cure that, too, and prevent having to do a drive cycle.
  12. tomconte
    May 15, 2010
    385
    Atlanta
    Tom Conte
    Why? I work on my car a lot. Planning to add a subwoofer amp soon. Don't want ear plugs.
    Doesn't make sense that it's hot wired around the cutoff. Then why have the batteries?
  13. tazandjan
    39,316
    Tom- Of course it makes sense that it is wired around the disconnect switch. Keeps the alarm battery charged if you shut her off with the disconnect switch over the winter. Not that I recommend that. The little $10 or so memory keeper with the 9 volt battery might be just what you need. Prevents making the system have to do a relearn every time you shut her off and might cure the siren sounding off.
    Understand now why you shut her off frequently.
  14. tomconte
    May 15, 2010
    385
    Atlanta
    Tom Conte
    what is this $10+9v you speak of, Taz?
  15. tazandjan
    39,316
  16. tomconte
    May 15, 2010
    385
    Atlanta
    Tom Conte
    Ok that's pretty simple. I could Macgyver one and hook it up to my battery keeper hookup. (Wonder though if putting a 9v battery in parallel with a 12v car battery would be a Big Boom...)
  17. tomconte
    May 15, 2010
    385
    Atlanta
    Tom Conte
    Nevermind, clearly it would be on the wrong side of the cutoff switch. Cig lighter socket it is!
  18. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    Hi Guys! Just installed the GM siren on my f355. Sweet, but every time i turn off the master switch my neighbors dogs bark too!!! Same as Toms. Maybe its the dogs i need to silence! Anyway id sure like to know the work around this as i dont get to take my beauty queen out very often and some advice would be most appreciated..How about the fact that if the keys are in the ignition,after 5mins she locks the doors! Lucky me!
  19. tomconte
    May 15, 2010
    385
    Atlanta
    Tom Conte
    Andy, a "computer memory saver" does seem to work.
    Thanks to Taz for the pointer!
    Tom
  20. Andy 355
    Jun 2, 2013
    434
    Thanks for the update Tom! Well done Taz! Ill grab one of these and give it a try. It will be plugged into the car and if that doesnt work ill plug it into the dog! Ha,Ha ;-)
  21. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    What happens if you pull the unit? Will the car run as it would with dead batteries.i.e- constant red led?
  22. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    By "unit" I assume you are referring to the alarm module?
    Should but the door locks may not work
  23. wong360
    wong360 Rookie
    Mar 14, 2015
    31
    With the siren unit out, my car door locks still works as normal.
    BTW the sirens are available because I just bought one from the GM dealership for $100 CAD.
  24. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    I heard with the GM the alarm with sound with any power disconnect.is this true?
  25. wong360
    wong360 Rookie
    Mar 14, 2015
    31
    I haven't tried it yet but I suspect that's true. Can tell you the GM siren will not activate when the car is in alarm mode. Lights flash, no siren. But no red light on dash and chirps with remote is well worth the money.
    I have taken apart my old oem siren and plan to repair the board. The GM siren is a great interim solution.
