360 - Alarm, Ignition, Siren Issue, Dead power | FerrariChat
360 Alarm, Ignition, Siren Issue, Dead power
Discussion in '360/430' started by jenglemn, Feb 19, 2023.
  1. jenglemn
    jenglemn Rookie
    Nov 28, 2014
    21
    Austin, Texas
    Jon Engleman
    360 alarm issue. I am having a problem with my 2000 360. Recently I hopped into the car and hit the key fob to unlock the engine lock, and quickly turned the key to start. (probably to quickly) Now- I get no power to the car, clicking coming through the radio speakers, and constant siren. Nothing is resetting the condition. Disconnecting the battery, does not reset it. The battery tests good and has 13.2 volts. The siren times out on it own.
    I have disconnected the battery and let it sit for several hours. Now when I reconnect the battery the siren immediately comes on, no power to the dash,. and flickering in the dome lights, and radio.
    Any ideas from the Community?
  2. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
  3. vrsurgeon
    vrsurgeon F1 World Champ
    16,528
    Charleston, SC
    Curt
    Replaced fob battery (I know stupid question..)
    Checked fuses behind drivers seat? Immobilizer fuse corroded or blown?
  4. Qavion
    Qavion F1 World Champ
    14,292
    Ian Riddell
    Can you expand on this? Do you mean no instruments, no interior lights, no external lights, window movement....? i.e. with the ignition on. An immobiliser issue shouldn't take out the whole electrical system.
    Where did you measure the battery voltage? At the battery or somewhere else?
  5. Fcar tech
    Fcar tech Karting
    Oct 22, 2021
    108
    Always nearby
    XXXX
    Battery voltage is 13.2..without a battery charger?
    Qavion likes this.
  6. Qavion
    14,292
    Ian Riddell
    I believe @Fcar_tech is hinting that you checked the battery with a battery tender attached. The battery may be faulty. When you turned on the ignition, perhaps the tender was trying to power the whole car. Assuming you use a battery tender, does it show the status of the battery?
    I suppose you could have an issue with the battery cutoff switch. They have been known to fail on rare occasion. It might have gone high resistance. i.e. not enough current getting through.
  7. jenglemn
    jenglemn Rookie
    Nov 28, 2014
    21
    Austin, Texas
    Jon Engleman
    New battery installed. Problem solved. Thanks.
    EastMemphis, Qavion and tomw like this.
  8. Fcar tech
    Fcar tech Karting
    Oct 22, 2021
    108
    Always nearby
    XXXX
    #8 Fcar tech, Feb 20, 2023
    Qavion, you caught that voltage# too.13+ volts,it was being charged while the reading was taken. Good job. Just because a battery has a "good" voltage reading doesn't make it a good battery. That's not how one should test a battery.
    That was easy..
    THINKFAST and Qavion like this.
  9. jenglemn
    jenglemn Rookie
    Nov 28, 2014
    21
    Austin, Texas
    Jon Engleman
    Hello, it was not on a charger. It went from fully functional to dead battery within one start . There was not enough enough enough amperage to disengage the immobilizer.
    Qavion likes this.
  10. THINKFAST
    THINKFAST Karting
    Jan 13, 2011
    195
    Earth, mostly ...
    From the reading (13.2) you gave, they must have figured you read the battery voltage wrong or the battery wasn’t good..
    Both Qavion and FcarTec picked up on that and questioned the voltage.. which was you problem. Glad your up and running.
  11. Qavion
    14,292
    Ian Riddell
    To be honest, I didn't notice the voltage reading at first, but the overall power loss pointed to a core power issue (such as a battery or battery wiring problem). The alternator hadn't yet been brought into play.
  12. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,853
    Memphis, TN
    It's amazing how many of these crazy 360 problems end up being resolved by a properly conditioned battery. When my mother was in Air Force Radio School (a place entirely unsuited to her), she told me she learned only one thing: First check the power source. That was back in the Korean war days and is still true today.
