Alarm Siren Unit and Fob Programming | FerrariChat
Discussion in '360/430' started by 4retr, Aug 8, 2010.
  1. 4retr
    4retr Formula Junior
    Nov 21, 2004
    384
    Southern California
    David B.
    Hello:
    Getting ready to program a new set of key fobs and just wanted to check if the alarm siren unit currently has a dead battery will affect setting up the new set of fobs.
    TIA
  2. tazandjan
    39,170
    #2 tazandjan, Aug 8, 2010
    David- If it affects the flashing of the LED, yes it will. Makes it impossible for you to perform certain of the ECU reprogramming functions. You can try and see if the flashing works or if it passes through the siren curcuitry. It will not hurt anything to try and see if the LED comes on and goes off after you have entered the PIN and are going through the 10 cycles of the LED turning on and off. Here is the latest copy of the document with engine start and ECU reprogramming checklists.
    Taz
    Terry Phillips
  3. 4retr
    Nov 21, 2004
    384
    Southern California
    David B.
    Thank you Terry!
