For Sale - Alarm sirens for F355, 360, 456, 550, 575 AND adapter cables | FerrariChat
For Sale Alarm sirens for F355, 360, 456, 550, 575 AND adapter cables
Discussion in 'Ferrari Parts & Collectibles' started by gobble, Mar 2, 2023.
  1. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Does your alarm LED stay lit when your car is running? Does your car not chirp when you press the fob? These are signs of a failed alarm siren. Over time (typically 20 years), the battery inside the siren leaks, the siren stops working, and the PCB board inside is eventually destroyed which causes the anti-theft fuse to blow.
    I'm selling replacement sirens for the F355, 360, 456, 550 and 575 that are compatible with Ferrari part #177148 (which sells for ~$1,000). These sirens are the same exact Bosch part that have been flashed with the proper software to function identically to the original. Price is $300.
    For those who have earlier models of the F355, 456 and 550 that contain the older (superceded) siren part #186593, the solution was always to buy a patch cable (part #180072 that Ferrari is selling for $230) to convert your car's wiring harness to fit the connector on the new siren. I just started manufacturing these cables and (for now) am selling them for only $50. My cable will be identical to the original, down to the wire colors and sticker. The connectors are OEM and not some China alternative.
    PM me if any questions!
    New siren and cable -
    Old 186593 superseded siren photo -
  2. OrmondStar
    OrmondStar Karting
    177
    Lake Mary, FL
    Richard
    I bought one from Mark after my OEM one destroyed my battery and it worked perfectly. Simple plug and play.
  3. FerrfanFL
    FerrfanFL Formula 3
    2,252
    Florida
    Ara
    the seller is wonderful to deal with. great car guy.
    fossilfuel and fatbillybob like this.
  4. Mike Morrissey
    Mike Morrissey Formula 3
    1,143
    Denver, Colorado
    Mike Morrissey
    YES, I too highly recommend Mark, "FerrariFobs", Fantastic in all that he does! :)
    fossilfuel and hrthornton like this.
  5. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
  6. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    I have the wrong superseded part number above. It's actually 180996.
  7. DBomb117
    DBomb117 Formula Junior
    Jun 20, 2019
    335
    Connecticut
    Dimitriy
    So for these is there any programming/learning involved? Do you just unplug the old one and plug this one in?
  8. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Just unplug the old one and plug in the new one. The car doesn’t need to learn it or anything like that.
    DBomb117 likes this.
  9. David Copeland
    David Copeland Karting
    Mar 9, 2019
    58
    League City, TX
    David Scott Copeland
    Can’t go wrong with anything from Ferrari Fobs! Best customer support that I have ever experienced. Thank you Mike!
    carnutdallas likes this.
  10. Mr. Uy
    Mr. Uy Formula Junior
    334
    Fort Worth, TX
    Charlie U
    Same issue if my light stays on, but I still get the beep from the remote?
  11. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Yeah I believe your battery has failed but has not yet started to destroy the PCB board.
  12. pkl03
    pkl03 Formula Junior
    538
    Sydney, Australia
    Peter
    Great work, looks like a great solution.
    Are you be able to replace the battery in the new units down the track, or will it be a matter of changing the siren again.
    Also, how do I know if I have earlier model siren, do I need to remove and check or was there a change over date.
  13. P1key
    P1key Karting
    Nov 9, 2022
    82
    Jeff Pike
    Do you ship to the UK? :)
  14. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Since the batteries typically last about 20 years I didn’t see a need to modify from OEM. That just seems like it’s asking for some other unknown trouble. My sirens have a late 2022 date code so they’re very fresh.
    I have heard there is an assembly number cutoff for the newer part number, but not sure what it is. Best to take a peek at what you have.
  15. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Yes
  16. pkl03
    538
    Sydney, Australia
    Peter
    Thank you, much appreciated.
  17. 575M Student
    575M Student Rookie
    Aug 31, 2023
    16
    SW FLORIDA
    Patrick
    Will this dead battery situation for the siren and pcb result in a "crank but no start" situation for the imobilizer?
    I am able to shut off the red dash light via my fob but no chirp. This is also a Euro 575M 2003. Not sure if that matters.
    Thank you so much in advance.
  18. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    No chirp tells me your siren is failing. Light flashing then off tells me the PCB hasn’t yet shorted or blown the fuse. Your immobilizer is doing what it should.
    Your car is not starting though? Have you checked fuel, spark, etc? I get calls somewhat frequently saying my car won’t start it must be the immobilizer, but the problem is ALWAYS something else. The first place I would look is the fuel pumps. I can’t tell you how many no start issues end up being the fuel pump.
  19. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    And you can always unplug the siren. The car will work just fine without it. The LED just stays lit when the car is running if the siren is unplugged.
  20. 575M Student
    575M Student Rookie
    Aug 31, 2023
    16
    SW FLORIDA
    Patrick
  21. 575M Student
    575M Student Rookie
    Aug 31, 2023
    16
    SW FLORIDA
    Patrick
    Def have correct pressure at the fuel rails. It went in for a broken F1 potentiometer arm. This has been replaced. But it has not started since.
    I did do the fob 3x button reset on the alarm. No joy. It does not have spark. It will not cycle past second gear. Cranks but no start. Thanks so much in advance!
  22. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    If it’s disarming it’s not the fob. No need to reset it.
  23. lfarrar
    lfarrar Rookie
    14
    San Diego
    Hello Mark
    I have a Euro 550 1998 / no OBE/ alarm light on. It still chrips when I unlock it. I would like to replace it myself.
    So I would like to order the alarm - do I need the wire too?
    Please give me a call when you can. In San Diego- 858 847-5450 cell
    Lynn Farrar
