Alarming noise on test drive. | FerrariChat
Discussion in 'Boxers/TR/M' started by DominicDBS, Mar 21, 2020.
  1. DominicDBS
    DominicDBS Rookie
    Aug 18, 2018
    14
    Dominic
    Hello Guys,
    I imported some Ferraris from the US and have just put a 87 TR on the road in England. The number plates were purchased today. On the way home we experienced a sudden worrying noise which sounded like a flat tyre.
    We discovered nothing and got the car home where i found that jacking up the front RHS of the car and putting a lateral force on the tyre in the 12 and 6 O’clock positions resulted in a metallic clicking or rattling noise. Something is loose!
    My question: is it likely just the central wheel nut or is it more likely to be a wheel bearing? Did anyone experience this?
    The wheels seem to track true enough using a rudimentary test and it has a recent catastrophically expensive service including new tyres and brakes. I don’t have a special TR wheel nut tool yet so i cannot check the torque on it until next week. The car has less than 4000 miles on it! I am not impressed with the people who did the service.
    Thoughts from real Ferrari guys please? I have had older exotics up till now.
    Cheers,
    Dom.
  2. BigTex
    79,368
    Houston, Texas
    Bubba
    Possibly a post on the UK Section will bring around a loaner tool?
    You've got to have it, should have been one in the boot
    While not an expert I think the wheel gets torqued off the ground, we have Owners that will know.
    Definitely a reflection on someone's talent, I agree.
    Good thing it did not pass you on the road shoulder!!!
  3. BigTex
    79,368
    Houston, Texas
    Bubba
    Wheel bearings "talk" a long time before failing in my experience.
    Betting your hex nut torque is off.
  4. DominicDBS
    DominicDBS Rookie
    Aug 18, 2018
    14
    Dominic
  5. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    906
    Homosassa, FL USA
    Ian Joubert
    Jack it back up. Have someone wiggle it while you get your head underneath and look at the backside of the wheel. You should be able to see if it is a loose wheel nut or if the movement is elsewhere. It could be wheel bearing, it could be a suspension mount. I am not familiar with the specifics of the car, but could be a ball joint, strut mount, ot a arm mount depending on the suspension configuration of the car. Regardless, with the aforementioned technique, you will be able to see where the movement is.
  6. DominicDBS
    DominicDBS Rookie
    Aug 18, 2018
    14
    Dominic
    Good reply. I will put it on a hoist on Monday and order a wheel nut device.
    Will post what i find.
    Cheers.
  7. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,424
    Alabama (was Mich.)
    Jeff
    Big Tex is right...the wheel center bolt needs to be torqued while the wheel is off the ground. The tapered surfaces need to be clean, with a thin film of anti-seize applied, the wheel slid onto the hub, and the nut tightened by hand..while hand tightening, try to wiggle the wheel, it should not have any movement. Then tighten to a whopping 325 ft-lbs of torque, or use the special spanner and lead hammer and pound away until there is no more movement. It could be a suspension issue but my gut says the wheel is not properly installed.
  8. DominicDBS
    DominicDBS Rookie
    Aug 18, 2018
    14
    Dominic
    Ok...thanks very much to all of you.
    Will post the result of this next week.
    Regards,
    Dom.
  9. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    Most important thing about tightening these single lug wheel bolts to spec, is that you have to do it multiple times. Mechanics often do it once then send the car on its way, not good. Torque it, drive a mile or two, torque it again. Drive 10-20 miles, torque it again. You should be good after that, but I periodically check all four just because. You'd be surprised.
  10. DominicDBS
    DominicDBS Rookie
    Aug 18, 2018
    14
    Dominic
    thanks Tim,
    wheel nut device from Superformance as soon as they open.
    regards,
    Dom.
  11. jgmblair
    jgmblair Formula Junior
    812
    Winnipeg, MB Canada
    Jeff Blair
  12. DominicDBS
    DominicDBS Rookie
    Aug 18, 2018
    14
    Dominic
    Thank you. Will do.
    Cheers.
    Dom.
