alignment specs for 99 modena | FerrariChat
Discussion in 'Technical Q&A' started by racerferrari, Apr 25, 2004.
  1. racerferrari
    racerferrari Rookie
    Jan 30, 2004
    7
    hey guys i'm got some new challenge wheels and i want to lower my car to whatever i can using the stock suspension...well my suspension guy needs to know the alignment specs.....anybody have them?....thanks..wayne
  2. racerferrari
    racerferrari Rookie
    Jan 30, 2004
    7
  3. Dave328
    Dave328 Formula 3
    Nov 24, 2002
    2,133
    Katy
    Dave
    We have the latest state-of-the-art Hunter machine at work. I know they have Ferrari listed in the makes, I'll look them up tomorrow and post them.
    Dave
  4. rexrcr
    rexrcr Formula 3
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    Ride height: 125.2mm front, 146.8 mm rear. Measured from the bottom of the suspension unit casting. NOTE: You must retain the same difference front to rear when lowering (i.e. chassis Rake remains the same at 21.6mm)
    Camber: F: -1 deg, 01' 35" +/-10' (negative one degree, 35 minutes, 35 seconds, plus or minus 10 minutes)
    R: -1 deg, 26' 14" +/-10'
    Total toe-in: (for wheel diameter of 495mm) 2.5 +/- 0.5mm front
    3.0 +/- 0.5mm rear
    Front caster (fixed): 5 deg, 57' 36" +/- 10'
    Tightening torque for front suspension lower arm: 55 Nm
    Nut for rear suspension lower arm: 60 Nm
    Be sure to check tire pressures and add driver and passenger weight plus 1/2 tank of fuel.
    Best regards,
    Rob Schermerhorn
  5. racerferrari
    racerferrari Rookie
    Jan 30, 2004
    7
    thanks for the info...i'll post a picture as soon as i get the car lowered..thanks..wayne..www.pulpracing.com
  6. PCH
    PCH F1 Rookie
    Apr 7, 2004
    3,007
    Anyone have alignment and ride height specs. for the CS?
