Alterantor?? 308 running great then started loosing power, and died! | FerrariChat
Discussion in 'Technical Q&A' started by Gast308, Jun 11, 2006.
  1. Gast308
    Gast308 Rookie
    Apr 22, 2006
    44
    San Jose, CA
    Randy Gast
    What next??? I just got this 308 running great and I was out for a spin, all of sudden I started loosing engine power....getting worse as I drove. Then, it died! Is the alternator bad? How do I check it?
    I tried to start it back up, but the battery was dead. Weird.... it is a new Battery, although I have been doing a lot of starts as I was working on the engine.
    I took the Batt out of car and did a 35amp quick charge for an hour, then put the Batt back in the can......varoom, she started right up and ran great again. I drove it around for about 30 minutes and on the way home, she started to loose a little power again...but I made home this time. When I went to start it again two hours later...the battery barely had enough juice to turn the engine over.
    Is there any correlation to the buzzer being on all the time? I disconnected the buzzer cuz it was driving me nuts.
    Once again....all I want to do is drive this horse!
  2. Steve Magnusson
    26,819
    As a first information gathering step -- measure the voltage across the battery at off, idle and ~2000 RPM.
  3. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Sounds like you have a major short going on. Recharge the bat and start it up and take a voltage reading to see if the alt is putting out arount 13V at 1000 rpm. If thats OK then you'll need to start searching for the short , circuit by circuit. I'd start with the buzzer
  4. Gast308
    Gast308 Rookie
    Apr 22, 2006
    44
    San Jose, CA
    Randy Gast
    OK...I did a voltage check by hooking the Volt Meter directly to the Batt terminal connections ( is that the proper hook up location ? ), here are the results:
    Batt w/ nothing on = 12.4V
    Batt w/switch only on = 12.3V
    Batt upon starting = 11.7V
    Batt once started at 1000rpm = 12.4 to 12.5V
    Batt when rev'd up to 3K and 4K rpm = 12.3V
    Back to idle = 12.3 to 12.2
    The voltage appeared to start to degradate as the engine ran. I turned the fans on as well to see if the alternator would pick up, but it did not.
    Results were that the Alternator did not get above 12.5V at any rpm level.
    Is it a bad alternator?
    Randy
  5. f355spider
    f355spider F1 World Champ
    18,044
  6. Gast308
    Gast308 Rookie
    Apr 22, 2006
    44
    San Jose, CA
    Randy Gast
    Does anyone have any advice on how to remove, repair and replace the alternator?
    Pic's would help..
    Randy
  7. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I dont have my car up and running to be able to check, so maybe someone else can comment as to the 308 having a charge light or how the car otherwise excites the alternator. If it does, it should light with key on, and go off with engine running. The light is used to initiate the charge circuit, so that if the bulb is blown or otherwise not making a connection, it would never excite the field windings to start charging.
  8. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    yup, the "G" lamp in the bottom right corner of the instrument panel should light when the key is turned to the run position, and goes out when the alternator is outputting.
    If the light bulb is good, but the lamp did not come on and the battery still drained, then I'd suspect a problem in the cabling between the alternator and battery (via the starter motor, I think).
    disconnecting the buzzer shouldn't matter, but for what it's worth, the buzzer is connected to the fuse box when the key is in the ignition. For the ground side, a switch in the door jamb will ground the buzzer directly, or the drivers seat belt switch will ground it through the seat belt/buzzer relay. Yanking the relay would tell you which of the two circuits is stuck to ground.
    Suggest popping the switch out of the door jamb and seeing if the wire connector has broken off and is touching metal.
  9. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    Verall has a great wite up about how to do this....The issue is that I can't find it :(
    We need a DIY section with all sticky's
  10. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Please post your car's info to your profile so we'll know which 308 varient you're talking about, there are some differences.
    wolftalk's right on, if the dash light isn't working, then either there's a problem in the bulb & associated wiring, or the alternator has failed. Unfortunately, to check out the wiring you have to remove the alternator.
    Search the archives for 'alternator' and 'removing' or 'removal'.
    I've posted alternator removal info 3 or 4 times to both the current and 'Old Ferrarichat'.
  11. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Before you start the "replacing alternator" syndrome, I urge you to do the tests suggested above. Be sure the alternator/battery connections are all good, the charge light works correctly, the grounds are all tight, etc.
    See if the battery is discharging too: with the car off, touch your + meter to the + post of the battery and the - side to the battery case. You may find voltage! If so, you need to clean up your battery, battery tray, etc.
    Ken
  12. Gast308
    Gast308 Rookie
    Apr 22, 2006
    44
    San Jose, CA
    Randy Gast
    Aahhhh....interesteing.
    I found the "alternator removal" write ups..thanks. Good insight...busted knuckles and cussing included! lol
    The "G" light never somes on when I turn the key. So, I am guessing that maybe I pulled a wire and something when i changed out the injectors and sensors???
    I hate electrical diagnosis....aaarrrggghhh.
    OK, I have a digital volt/amp meeter, so I will put my engineering training to work.
    I hope it is truely not the alternator...just the thought of the removal process makes me think about selling.....
    Good feedback guys....thanks so much so far!
    Randy
  13. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    This one may be easy then! Change the light bulb and you have a good chance of fixing the problem! If the light still doesn't come on, you have to trace the path backwards with your meter to see where the problem is.
    Ken
  14. Gast308
    Gast308 Rookie
    Apr 22, 2006
    44
    San Jose, CA
    Randy Gast
    Is this another Ferrari " special " light bulb or can I get it at the local Kragen's?
    My fingers are crossed....
    Randy
  15. BigTex
    79,380
    Houston, Texas
    Bubba
    I think the bulbs are all pretty standard....and the alternator is not as hard as say.....a blown front header!
    Hang in there...
  16. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    No, you're in it for the long haul now! Can't sell it with a bad charging circuit! ;)
    Randy, you figured out the last problem and you will figure this one out too, with the expert's help here. All Ferraris are like this--especially 308s. They come with delayed maintenance issues and things the previous owner ignored that you have to sort out. Once you get all the bugs out of the car, it will be very reliable, I promise.
    Birdman
  17. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    I echo this sentiment; I went through issues with my car that seemed overwhelming at first. Still do sometimes! Something will go wrong and my first thought is I'm screwed. But then I remember I've troubleshot lots of things and eventually have fixed them all. It's just a car, not brain surgery. So try to not feel overwhelmed first off. This is a good problem you have in that you CAN figure it out yourself, with help from other 308 guys. It's not a leaky head gasket!
    Alternator R & R is your worst case scenario; rebuilds are usually in the $120 range so it's cheap. And I bet your alternator is okay; it's a ground/bad wire/bad bulb type thing. The key is to get a wiring diagram, and take it one step at a time.
    Ken
  18. Gast308
    Gast308 Rookie
    Apr 22, 2006
    44
    San Jose, CA
    Randy Gast
    thanks Guys! I will find it...you have given me the confidence to go on.
    I feel al little better that I have a shot of finding it with out having to R & R the alternator.
    I will check it out and post my results.......
  19. Gast308
    Gast308 Rookie
    Apr 22, 2006
    44
    San Jose, CA
    Randy Gast
    OK..I changed out the bulb and Wala! The light works and I heared the alternator charging ( light whurr sound ).
    I took the car out for a short cruise and she did fine.
    Thanks again guys! I hope to see some of you on the road!
  20. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Ck the voltage across the battery terminals with the car running and the alternator light off. Should be roughly 13.25v - 14v before you break out the Champaign.
    I fixed 25 minor issues on my 308 within the 1st 3 months of ownership(fuseblocks, relays, antenna etc), 9 months later it's been flawless and a blast to own. Hang in there and enjoy !
