News
Alternator 308 Conversion ?
Discussion in '308/328' started by johnny308, Sep 18, 2019.
  1. johnny308
    johnny308 Karting
    Dec 3, 2011
    143
    Greenfield, MA. USA
    Hello Ladies and Gents,
    My 1980 308 has a weak alternator it is out and will be repaired. However, there seems to be an issue with
    these Bosch units and the cost of replacing them. It seems to me that there must be an alternative unit that
    can be used. For example I have a Triumph TR3 with a antique large heavy low output generator. It has been replaced with General Motors model CS130 alternator. MY two Triumph TR8's use the same unit. I think my 1987 Jaguar XJ-6 has again the same unit. Please no Lucas jokes here.
    It just seems like something else may be fitted.
    Has anyone been down this path?
    Safe motoring
  3. derekw
    derekw Formula 3
    Sep 7, 2010
    1,308
    London, UK
    Derek W
    They are not hard to rebuild-- check out my blog "derek's 308..." Parts are cheap and available. I have a couple of 65amp Bosch copies on ebay and may know someone coming stateside who can bring one but they are £165 so much cheaper to rebuild. If your power is down but still some charging then the brushes may be finished and only connecting intermittently (very easy and cheap to fix) or one of your diodes may be out (only $5 but change the brushes and bearing while in there.) If you can't find the parts send me a PM and I'll send you what you need.
    johnny308 likes this.
  4. johnny308
    johnny308 Karting
    Dec 3, 2011
    143
    Greenfield, MA. USA
    Thank You!
    We have it out and apart. We CANNOT find anything wrong. Yikes.
  5. johnny308
    johnny308 Karting
    Dec 3, 2011
    143
    Greenfield, MA. USA
    Hello,
    How do I find your blog?
  6. thorn
    thorn F1 Rookie
    2,884
    Tallahassee, FL
    #5 thorn, Sep 19, 2019
    Have you put it on an alternator tester, or tested the diodes, etc?
  8. johnny308
    johnny308 Karting
    Dec 3, 2011
    143
    Greenfield, MA. USA
    We have done ALL of the above. It puts out about 13.5 volts and no current.
  9. thorn
    thorn F1 Rookie
    2,884
    Tallahassee, FL
    How are you measuring voltage and current?
  10. derekw
    derekw Formula 3
    Sep 7, 2010
    1,308
    London, UK
    Derek W
    Google Derek’s 308. Sounds like the regulator (which also holds the brushes.)
