Alternator Belt Sizes - Fixing Squeal | FerrariChat
Discussion in '308/328' started by Javelin276, Aug 21, 2006.
  1. Javelin276
    Javelin276 Formula Junior
    Jan 16, 2005
    512
    Idaho
    Thor Zollinger
    My Mondial-8 alternator belt squeals and I was wondering... Do later Mondial's and 308's use a wider belt and pulleys? If they do, I could swap out the alternator pulley, water pump pulley, and crank pulley and install a wider belt and kill the problem permanently with a minimum of effort.
    Mine is the earliest version Mondial with the smallest alternator, 7mm x 975mm belt.
    What size is the belt on the later cars?
  2. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,822
    No, they all use the same Gates 7M "Polyflex" (IIRC) cross-section. Circa '84 they went to separate belts for the Alt and WP to help with the issue -- see:
    http://ferrarichat.com/forum/showthread.php?t=116156
    Also, do a search on 7M975 and/or 7M1000 for other threads.
  3. Javelin276
    Jan 16, 2005
    512
    Idaho
    Thor Zollinger
    Thanks! Dang, I wish I'd known about the Ferrari upgrade a month ago when I had the engine out.
