Alternator fuse box melting | FerrariChat
Discussion in '206/246' started by snowsports1, Jan 13, 2015.
  1. snowsports1
    snowsports1 Formula Junior
    Jan 31, 2013
    918
    Brian
    Hi a common problem it seems but can anyone tell me why my alternator fuse box is getting hot and melting! I have a new wiring loom, recon alternator and I have installed a modern fuse carrier in the old alternator fuse box housing.
  2. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  3. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    +1
    Usually a corroded connection or a loose connection (screw terminal not properly tightened as example)
  4. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,203
    Norfolk - UK
    Tony
    Brian
    I note you have recon alternator and new wiring etc. You must get this fixed as a matter of priority. It will do a lot of damage to the cable & other cables in the loom.
    The Alternator should charge the battery between 13.8 and 14.3 volts, I recently replaced my alternator because it was overcharging. Check voltage regulator and the field current.
    As others have said loose / bad connections
  5. dino clay
    dino clay Karting
    Oct 31, 2007
    185
    san mateo, cal
    clay cavanaugh
    check connections on AMP GAUGE NOW
  6. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    any updates?
    Where was the high resistance found?
  7. frankwissman
    frankwissman Karting
    May 6, 2006
    63
    Charleston, SC
    Frank Wissman
  8. snowsports1
    Jan 31, 2013
    918
    Brian
    update I have found by chance that the yellow wire from the dinoplex is feeding power to the fuse rather than the other way! The dinoplex isn't working and the conventional coil setup clearly isn't wired correctly. So I have concentrated on doing a Bosch conversion for the ignition first then this may solve two problems in one, frank Your link doesn't seem to work?
