alternator issues on 550 | FerrariChat
Discussion in '456/550/575' started by thibaut, Sep 27, 2005.
  1. thibaut
    thibaut Formula Junior
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    hello to all ferrari experts
    My car has been sitting for almost three weeks so i wanted to run it a bit to recharge the battery.
    tried to start my 550 today and :
    - alternator light on the left stays on
    - center warning screen shows a battery
    giving a few blips with throttle, the alternator light on the left flickeled but returned.
    Is there anything i can do before getting the car on a flatbed ?
    cheers
  2. thibaut
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    sorry.. further question : is the alternator a known weak spot for the 550?
  3. tiara4300
    tiara4300 Formula Junior
    Feb 27, 2005
    650
    miami ,fl.
    Adam
    Not really a problem with the alternators on these cars. The accessory belts need to be checked now and again. I would check if the belt hasn't come off.
  4. f355spider
    f355spider F1 World Champ
    18,048
    Most likely just a bad battery that is no longer capable of taking a charge...replace it and you will probably be fine. The factory FIAMM batteries are not known for their longevity.
  5. tritone
    tritone F1 Veteran
    7,204
    On the Rock
    James
    FWIW, in all my prepurchase research, on FChat archives, calls to service managers, discussions with current/former owners, alternators never showed up as an issue with 550's......
    james
  6. thibaut
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    the battery is only 3 years old. Even if the car is not used much, it shouldn't be that bad yet ? the car is 98.
  7. MarkCollins
    MarkCollins F1 Rookie
    Jul 2, 2002
    3,202
    South England
    Mark Collins
    Yep original Batteries are pretty useless, if it's 3 years old and you left it for 3 weeks without a trickle charger then it's probably had it.
    You could try using a proper battery charger and charge it for 24 hours, it might recover but lead acid batteries don't like being fuly drained and left flat for periods
    my advice, buy a new battery (not from a Ferrari dealer!) and a trickle charger
