Alternator over charging | FerrariChat
Discussion in '308/328' started by ragtop1, Jan 29, 2021.
  1. ragtop1
    ragtop1 F1 Veteran
    5,246
    Ontario
    Larry Warren
    I had my alternator rebuilt. They replaced the bearings and voltage regulator. The tech demonstrated the bench test to me, indicating a 14.2 volt charge. When I reinstalled it back in the car, It read 16.5 volts at the battery. I believe that's a dangerously high input.
    Any ideas ? I don't see a voltage regulator on the 308 wiring diagram.
    Thank you
  2. Imatk
    Imatk Formula Junior
    May 6, 2007
    777
    The voltage regulator should be on the outside of the alternator. You can also buy adjustable voltage regulators here:
    https://www.prancingmoose.com/AdjustableVoltage.html#internal
    I got one for my VW which has a Bosch unit... I'm guessing it's similar if not the same as the 308 regulator but you can always email him... he's good about getting back with folks.
  3. ragtop1
    ragtop1 F1 Veteran
    5,246
    Ontario
    Larry Warren
    Thanks Imatk
    Yes, Should have explained better. I was referring to a possible secondary regulator in the car electricals, apart from the one on the alternator. Anyway thanks for the feedback and the link. I definitely like the external adjustable one.
    Imatk likes this.
  4. BigTex
    79,386
    Houston, Texas
    Bubba
    That's odd, I don't think there is any items in the circuit past the output on the unit..
    Anyone??
    Something changed on the way home?
    Grounded to the frame??
  5. Dancia
    Dancia Rookie
    May 15, 2015
    35
    I believe the only voltage regulator is a (replaceable) part of the alternator.
    I would check voltage at the battery and the alternator big wire.
    I can’t think of another regulator.
    Or where are you seeing / testing 16+ Volts?
  6. ragtop1
    ragtop1 F1 Veteran
    5,246
    Ontario
    Larry Warren
    Yes, I agree. There isn't anything beyond the alternator per the wiring diagrams that I have. My main concern is why is the alternator showing 14.2 volts at the repair shop test bench and 16.5 volts installed on my car at the battery? ....car idles at 1000 rpm
    The windows sure go up and down a lot faster
  7. ragtop1
    ragtop1 F1 Veteran
    5,246
    Ontario
    Larry Warren
    I'm reading 16.5 volts at the battery. I will put my meter on the live alternator post tomorrow .. Good idea
  8. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    What does your meter read at the battery when the engine is not running?
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,971
    Isle of man- uk
    Also what happens when you put a big load on like the headlights and heater motor
  10. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I'm curious what your battery voltage is when the car is off.
  11. ragtop1
    ragtop1 F1 Veteran
    5,246
    Ontario
    Larry Warren
    battery is reading 12.9 volts - not running
  12. ragtop1
    ragtop1 F1 Veteran
    5,246
    Ontario
    Larry Warren
    12.9 volts not running
  13. ragtop1
    ragtop1 F1 Veteran
    5,246
    Ontario
    Larry Warren
    12.9 volts with a load
  14. ragtop1
    ragtop1 F1 Veteran
    5,246
    Ontario
    Larry Warren
    I reterminated the two connections at the alternator and starter with new ones as they were showing signs of corrosion. the reading at the battery while runnining is now 13.8. i don't know what changed but I'm quite pleased with the readings now. The cable running from the alternator to the starter seemed to be the culprit.
  15. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    13.8 is kind of low but barely enough to charge the battery, you should have at least 14.2 volts. While running.
  16. ragtop1
    ragtop1 F1 Veteran
    5,246
    Ontario
    Larry Warren
    Thanks Mike, I check the belt tension
  17. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,971
    Isle of man- uk
    Would not expect that if stopped, as its a 12 volt battery. Decent voltmeter ?
    Voltage regulator is working as the volts are maintained when you put the lights/ heater on. If it had dropped then avr problem
  18. ragtop1
    ragtop1 F1 Veteran
    5,246
    Ontario
    Larry Warren
    I did take readings with 2 different meters. they were about 0.15 > 0.20 volts apart. I'll check again today since it's been sitting overnight without the trickle charger. thanks
  19. Luis A.
    Luis A. Karting
    Jul 14, 2010
    97
    Milwaukee, WI
    A flooded “12 volt” lead acid battery will read ~12.7 Volts at full capacity, when measured after it’s been off the charger or load for a few hours. An AGM battery will be higher, at around 12.8-12.9. A 12.0 volt reading would correspond to a state of charge of 25% capacity, nearly completely discharged.
    ragtop1 likes this.
  20. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,971
    Isle of man- uk
    I have got a little digital voltmeter that plugs into the power socket, gives a number readout like a neon style, very cheap from Amazon. Handy to have if you get problems on the road
    ragtop1 likes this.
  21. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    What voltage are you expecting?
  22. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,971
    Isle of man- uk
    Mine has a standard battery and 11.8 is about normal if its been sitting, But mine has a tracker fitted which is a constant draw. I get about 13.8 when it is running
  23. ragtop1
    ragtop1 F1 Veteran
    5,246
    Ontario
    Larry Warren
    I like what I'm hearing. If Mike32 is happy with a 13.8 running charge (my reading also) I'll accept it for the time being. Although 14.2 is more desirable per miketuason's remarks, I'll try this for now. I'm very pleased that it's not reading 16.5 running any longer.
    I'm a pro at changing out the alternator now. I think I've had it off and on at least 5 -6 times, and 2 trips to the rebuild shop to get this sorted. Thank you all for your input
  24. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,971
    Isle of man- uk
    Any alternator only needs to produce more than the battery nominal volts to charge it. If you start getting the charge volts too high you are going to start blowing bulbs etc.
  25. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    That's your battery telling you it's time to replace it if it can't hold a charge at at least 12.2. A new healthy battery will be a lot closer to 13V.
