Alternator Warning Light Not Coming On | FerrariChat
Discussion in '308/328' started by Dinodog, Aug 4, 2010.
  1. Dinodog
    Dinodog Karting
    Sep 2, 2009
    78
    Birmingham,Alabama
    Dean Matthews
    1981 308. With the ignition switched on the alternator( battery) warning light is not coming on. The car will fire up and run fine with no problems. Have not driven it in a few weeks, nor since I noticed the light not coming on. I have checked the bulb and it is fine. Last time this happened it was on a 944 and the alternator was not charging. When I took the 944 alternator for a rebuild the tech told me the contacts were stuck open and I could have possibly temporarily fixed the problem by banging on the alternator with a wrench.
    Any ideas on what to check? Is the regulator located inside the alternator? I think I recall the wiring diagram showing the completion of the warning light circuit coming of the regulator and from the top of fuse#3. I would just take the alternator out and rebuild it but as luck would have it ( for me and the new owner) I just sold the car and the next trip is a short one down the block in a few days to an enclosed transporter.
  2. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Nothing needs checking. Your regulator is on it's way south and you have been given proper warning. Silly to fight it.
  3. Dinodog
    Dinodog Karting
    Sep 2, 2009
    78
    Birmingham,Alabama
    Dean Matthews
    Thanks Paul, can you please tell me if the regulator is external or internal? If external where it's located?
    Thanks!
  4. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    It's internal and mounted on the back of the alternator. There is a heat shield covering it so you need to remove the alternator to replace it.
  5. Dinodog
    Dinodog Karting
    Sep 2, 2009
    78
    Birmingham,Alabama
    Dean Matthews
    Thanks Steve!
