Alternator/water pump belt failure, any theories | FerrariChat
Discussion in '348/355' started by Pepsi10, Oct 17, 2021.
  1. Pepsi10
    Pepsi10 Formula Junior
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    Guys, I would appreciate any thoughts.
    I had both rubber accessory belts break yesterday, one is labeled Dayco, K5/199830, the water pump belt/alternator belt. The other belt has come off its pulleys, I can see it hanging out of the bottom of the car. But it is jammed where I can not get to it, until I get more room under the car to work on it.
    My theory is that the K5 belt broke, and somehow caused the other belt to come off it’s track also.
    I was able to limp the car to my personal garage. It stalled out as I pulled in front of my garage. The K5 belt puked itself out onto the driveway, just then. That’s how I recovered that broken belt.
    I no longer really trust anyone within 700 miles to work on the car. So I am gearing up to try and replace these belts myself. I will give Daniel(Ricambi) a call on Monday about replacement belts.
    I have read a couple threads here about replacing the belts.
    The now broken belts were replaced less than 2000-3000 miles ago. During a major service. And the K5 belt, that I am looking at, looks virtually new, except for the fact that it is now broken.
    Here’s my question. Any theories on why this would have happened? I guess my best idea would be that one or both belts were incorrectly tensioned at the Ferrari dealership that did the major? (A water pump was replaced during that service also). So that belt flew off, and then caused the other one to come off?
    Also, if anyone has any secrets that come to mind, about replacing these belts. I am all ears. And will continue looking through old threads (The one I printed out was one where Terry and 355Gary were discussing alternator removal, and belt tightening).
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    There are 3 belts. Which two are broken?
    1. Power steering - water pump belt
    2. water pump, alternator. main pulley belt
    3. AC belt
    Which two?
    The K5 belt... is that the date code? 199830 ? Seems really old
    If the belts were mis-aligned during installment, it would break within 20 miles of driving, and not 2000 miles.
    If the belts are not tensioned correctly or very old, then they would slip or break and cause other belts to be slipping as well. Those belts all have date codes. Find and read them.
  3. Pepsi10
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    My apologies. I only saw two belts in this diagram. Not counting the timing belt in the back of the image.
    As I said, one belt, I do not have access to right now. It is jammed where I can not get to it.
    The other belt has two numbers on it, 18422 068 0805 and 199830. And K5. According to at least two threads, one here on FChat, for Dayco belts, the first two numbers indicate the year the belt was built. So I suspect the 199830 = built 2019. But I am not expert on reading those codes. If it is the other number, 18422etc. Then maybe the belt was built in 2018.
  4. Pepsi10
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
  5. yelcab
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    That is a really clean break across the belt. I do not know what would cause one belt to break let alone two belts. You will find the answer when you can lift the car up, remove the panel from underneath and inspect the AC compressor as well as the other belt tensioning device.
    Pepsi10 likes this.
  6. Ricambi America
    Sponsor Owner
    No. 199830 is simply the Ferrari part number for that belt.
    The three accessory belts on an F355 will be stamped with part numbers:
    1 x 199832 POWER STEERING BELT
    1 x 199830 AC BELT/ALT BELT
    1 x 199833 ALTERNATOR BELT
    Pepsi10 likes this.
  7. IvanRico
    IvanRico Karting
    197
    Westchester NY
    Ivan Rico
    Silly question. Does anyone replace the now 20 something year old belts that come in the toolkit? This way if you’re on a long road trip they might be of some use to a mechanic instead of worthless?
  8. Pepsi10
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    Seems like a very good idea, for the $20 they cost from Ricambi. OTOH I have not had a belt break…ever, until this case. In a bit over 40 years of driving. You usually can tell if they are loose by a squeal etc.
  9. 26street
    26street Formula Junior
    Jan 30, 2021
    469
    Westchester New York
    Mark k
    That is a very clean brake in the belt maybe it was defective but I would check all pulled and accessories for play or damage
    After installing make sure proper tension is applied and then recheck after driven a few times
    I would not have driven the car with no belts that will make more problems and it stalling out when you got home I hope was from the battery going dead and not anything else
    Pepsi10 likes this.
  10. Pepsi10
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    Yes. Gauges were all normal. We will see when I get it all opened up.
  11. 05elise
    05elise Karting
    Jul 20, 2011
    211
    Sharpsburg, GA
    Dan
    The clean break on the pictured belt is indicative of something loose in the belt drive area getting drawn into a pulley and snapping the belt as it got stuck between the pulley and belt. It is quite possible the other broken belt is what got trapped and broke this one after it broke and flew around the pulleys. You will have to get a good look at the front of the engine, the belt drive pulleys and the other broken belt to figure out what caused the failures. Check all the pulleys and tensioners for one that has seized up as that could have been what caused the first belt to break.
    Pepsi10 likes this.
  12. Pepsi10
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    Update. I looked at the pulleys on the alternator and AC compressor and they both spin freely. As does the tensioner. The water pump belt, up above, looks brand new and is fine and still in place. A photo of the destroyed alternator belt is below. It looks older, but it has been through the wringer, so, for now, I will give the benefit of the doubt to the Ferrari dealership that did the major and assume it was changed out for a new belt.
    As I do not see anything strange. My plan is to replace the AC compressor belt, and the larger alternator belt.
    Alternator belt: I understand how to release the tension to replace the larger alternator belt, there is a central nut on the tensioner (A in diagram above), that has to be loosened, and then the bolt on the bottom(B) of the tensioner needs to be rotated clockwise to loosen that assembly, so hopefully the alternator belt can be put in place and then adjusted to proper tension after.
    For the AC compressor belt, I have read threads here where people have replaced the alternator, but, so far, I do not see a thread where people talk about the procedure for releasing the AC compressor, allowing one to fit the compressor belt. There appear to be at least three bolts holding the AC compressor in place (two of which are circled in the bottom photo), and then a separate adjustment bolt (circled also on the top of the photo). The three bolts appear to be not especially easy to release, tight quarters.
  13. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Any chance that a foreign object got into the belt path? Very unusual failure.
  14. Pepsi10
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    I will have to see if something, like a band clamp, came loose on the top part of the engine, but I don’t think so.
    No one has been working on the car for a while. Hundreds of miles since the hood has been opened. All the under trays were in place. This all happened after a friend, him driving, but with me in the passenger seat, took the car for a bit of run, maybe 20 miles. We cooled it down. Parked it for 15 minutes. And then I was returning it to the garage when this all happened.
    I was sure I was going to see either of the accessories had not been tightened up. But everything looks normal, tightened down. There were a couple wires, that were connected, but seemed a bit close to where the belt would be, for example one of the AC compressor wires, but I have a feeling that is just packaging
    efficiency.
    I will attempt to put it back together, and see if I see anything strange (but, for now, without the undertrays). I think I know how to do the two belts.
  15. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    Having never done this procedure on a 355 and just seeing the above drawing for the first time would you not adjust the tension with bolt "E" in or out accordingly? "C" & "D" look to be front and back mounts. Or is it just to early for me on a Saturday. :confused:
    Pepsi10 likes this.
  16. Pepsi10
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    Sounds right. C and D lock the position. E is the adjusting bolt. I was skeptical of the English directions. As the Italian ones mention bolt E. But the English ones do not.
  17. 05elise
    05elise Karting
    Jul 20, 2011
    211
    Sharpsburg, GA
    Dan
    I think you are correct. Bolt “E” is mentioned in the paragraph in Italian but completely missing from the English translation. Bolts “C” and “D” look like lock down bolts once the tension is properly adjusted using bolt “E” to me.
  18. m.stojanovic
    m.stojanovic F1 Rookie
    3,231
    Serbia - Niš
    Miroljub Stojanovic
    Bad translation from Italian and probably also some typing errors in English. Loosen C and D to allow sliding, adjust via E, tighten back C and D.
    Pepsi10 likes this.
  19. yelcab
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    Pepsi10, you know that the AC pulley freely spins does not mean much, right? You need to see if it is frozen up while the clutch is energized.
    taz355 and Pepsi10 like this.
  20. Pepsi10
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    #20 Pepsi10, Oct 23, 2021
    I did not know that, so I appreciate the input, but I was worrying about it once I saw everything looked okay with the car off, and not warmed up-that one of these pulleys/tensioners might be freezing up during use.
    Side point is that the stop button inside the car was depressed/engaged, as it usually is when I am driving the car. But I do use the AC occasionally, so if something was wrong with the pulley, it might cause the belt to wear.
  21. IvanRico
    IvanRico Karting
    197
    Westchester NY
    Ivan Rico
    Did you have the A/C on when it failed? If you didn’t then it wouldn’t seem likely to be the A/C compressor that’s the culprit.
    Pepsi10 likes this.
  22. Pepsi10
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    Agreed. No. Both dials inside the car were/are in the off position. And the stop button was/is still depressed/engaged.
    IvanRico likes this.
  23. Pepsi10
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    Minor update. Releasing nuts/bolts C and D: There is not a lot of room to work on these bolts, but I got them loosened up which allowed me to rotate the alternator toward the engine. In theory allowing me to mount the belt for the compressor. But. Something is preventing enough movement. The belt will not quite fit over the two pulleys. I am taking a break.
    A side point for those trying this at home. Maybe I should have released the tensioner using points A/B in the photo below. Getting the compressor belt onto the main pulley, required me to carefully thread it between the tensioner and the main pulley. If I had released the tensioner. It might have been easier.
  24. Pepsi10
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    AC compressor belt installed. Next time I will be an expert. This time, it took a lot of time. Looking at the compressor from below the car, in the photo below, you will see 3 circled areas. The most obvious is an adjustment bolt in the center. Flanking that screw, are two hold down bolts (17mm). These bolts must be loosened. One of them requires you to also have a 6mm hex head to keep it from rotating as you try to release it. The central screw, in the photo, must also be released, which will give you room to push the compressor toward the engine and fit the belt. One does not need to mess with any other bolts.
    Hint for new players. Accessing the bolts to release the compressor is difficult, but if you reach your arm UP through the engine cradle, you can get a better angle on at least one of the bolts. The center bolt, and the flanking bolts correspond to bolts E, C and D, in the image labeled compressor belt tension image above.
  25. Pepsi10
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    I am having a problem getting the alternator belt installed. First I loosened the central bolt on the tensioner. Next there is a bolt at the tensioner 6 o’clock. I rotated this bolt clockwise. This clockwise rotation of this bolt brings the tensioner down, I can see that happening, so that the belt is more in line with the main pulley, and the alternator pulley, creating more slack in the belt. But even with all the adjustment released, it has so far not been possible to get the alternator belt installed. Just not enough slack in the belt. I will keep thinking.
