Aluminum behind the door hinge | FerrariChat
Discussion in '308/328' started by TommyA, Jul 7, 2021.
  1. TommyA
    TommyA Formula Junior
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    The body shop removed the doors and hinges for repaint, there was a strip of aluminum glued behind them. Any idea the purpose of it?
  2. Talon38
    Talon38 Karting
    142
    Austin, Texas
    Mike Lambert
    Might you have a photo?
    waymar likes this.
  3. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    It was on all 4 brackets on the side that bolts to the fender. Unfortunately I took the picture after they were removed. It was a thick piece of aluminum
  4. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Probably shims to get door gaps and hinges aligned.
  5. Talon38
    Talon38 Karting
    142
    Austin, Texas
    Mike Lambert
  6. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    That is my thinking but was not sure.
  7. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    That is correct... aluminum foil was glued on all 4 of them.
  8. Du_Man
    Du_Man Formula Junior
    320
    Dallas, Texas
    Derek
    I did not have any alum shims on my recent door removal - prob for door alignment like Simon said.
  9. Vonbarron
    Vonbarron Formula 3
    2,263
    Westside Mofo
    S B
    The aluminum sticky tape is used to give it a positive locking surface so your not steel on steel. It’s been on several cars I’ve worked on from 77-83, no idea how long a date range used
  10. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    Is it necessary to put something on them again since they were removed?
  11. Vonbarron
    Vonbarron Formula 3
    2,263
    Westside Mofo
    S B
    I have only removed it from one of the race car 308s, the others I left on the hinges. I myself would not fret over finding some aluminum tape. As long as you torque down those hinge screws you should be fine.
  12. Vonbarron
    Vonbarron Formula 3
    2,263
    Westside Mofo
    S B
    I would advise not painting the hinge mounting surface though same as the door pillar, the paint will break down and become loose overtime, those doors are damn heavy
    waymar likes this.
  13. Talon38
    Talon38 Karting
    142
    Austin, Texas
    Mike Lambert
    Really good info! Thanks!
  14. TommyA
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    I was thinking using POR15 on them...
  15. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    US doors are heavy. Euro doors weigh much less.
    miketuason likes this.
  16. Vonbarron
    Vonbarron Formula 3
    2,263
    Westside Mofo
    S B
    If you do just check tightness every once in awhile, I’ve started switching to tapered stainless hardware in the hinges since I’ve had to drill some out. My cases are extreme though
  17. afterburner
    afterburner F1 Rookie
    3,475
    Switzerland
    Urs STEMMLER
    It's called Zincofil and is a sacrificial galvanic anode corrosion protection. You should reuse or replace it.
  18. afterburner
    3,475
    Switzerland
    Urs STEMMLER
    Nope
  19. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    And glass ones lighter still...
    ferrariowner likes this.
