Ambient Ait Temp. Sensor Location? | FerrariChat
Discussion in '360/430' started by malibumk, Dec 18, 2011.
  1. malibumk
    malibumk Karting
    May 14, 2002
    167
    Malibu, CA
    Mike Klein
    Does anyone know where this sensor is located?
    I've got Code 0074 "intermittent".
    Thanks,
    MK
  2. Under PSI
    Under PSI F1 Rookie
    May 13, 2005
    4,240
    Phoenix
    Jim
    I believe it is that little "lump" under the driver's side outside mirror. At least that's the one that gives the outside temperature reading on the dash.
  3. djastral69
    djastral69 Formula 3
    1,896
    Fl
    David
    That's it...
  4. malibumk
    malibumk Karting
    May 14, 2002
    167
    Malibu, CA
    Mike Klein
    Is this the input to the OBD II system? Because I have code 0074 "Intermittent Ambient Air Temp Sensor"
    Thanks all,
  5. malibumk
    malibumk Karting
    May 14, 2002
    167
    Malibu, CA
    Mike Klein
    Lessons Learned Feedback; YES the ambitent Air Temp Sensor under the Driver Side Mirror is for BOTH the A/C System and the OBD II.
    What I found was an intermittent fuse for the a/c control (10A behind drivers seat) and when the a/c is out, it also triggers the Check Engine light.
    Fix fuse.....fix both.
    MK
