355 - Amsoil... API GL-4 or Gl-5 Oil For Gearbox Oil? | FerrariChat
355 Amsoil... API GL-4 or Gl-5 Oil For Gearbox Oil?
Discussion in '348/355' started by PaulK, Jul 31, 2022.
  1. PaulK
    PaulK F1 Rookie
    4,789
    Michigan
    Paul
    Hi Everyone,
    I am narrowing everything down for my project and I need to figure out what oil to use for the gearbox.
    I have had good results with Amsoil in the past but never used their gear oils.
    Sadly the workshop manual does not state what grade of oil to use. The factory recommended oil is rated for both GL-4 and 5 (so its really a GL-5 oil).
    This one (Manual Transmission & Transaxle Gear Lube 75W-90) looks to be perfect except that it is certified at GL-4. Is it safe to use a GL-4 rated oil in the transmission? I know it is better for the synchros but these cars are made to go at a high speed which is what essentially the GL-5 rating is for. As far as I know this oil hasn't been discussed on here yet.
    https://www.amsoil.com/p/manual-transmission-transaxle-gear-lube-75w-90-mtg/
    The other one I am considering is the Amsoil Severe Gear 75W-90. I am reluctant to use it because I remember one member here having a bad experience with it, and I am not sure if they used the Sliplock additive or not. But at least this is GL-5 rated.
    https://www.amsoil.com/p/severe-gear-75w-90-svg/
    What do you guys think? My other option is to use the dealer oil which I am not opposed to but would prefer to stay loyal to Amsoil.
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I had terrible luck with thier gb oil. I mean it turned my car driving into a chore I did not enjoy. Shell spirax made the gb feel like a new car, can even shift into second when cold. Real pleasure to drive
    Still use Amsoil in the engine however.
    Sent using FerrariChat.com mobile app
    ShineKen and PaulK like this.
  3. Rifledriver
    37,246
    GL5 is really a hypoid differential oil and GL4 is really a transmission oil. Ferrari specifies GL5 even though the 355/348 transaxles do not have a hypoid differential. Many people have used GL4 oils in those for years including track cars and Challenge cars for many miles with no ill effects.
    GL5 oils are made with additives that make the oil particularly slippery for the high shear encountered in hypoid gears. That slipperyness inhibits the function of syncros in many transmissions.
    Gialllo uno, PaulK and Ferrarium like this.
  4. PaulK
    PaulK F1 Rookie
    4,789
    Michigan
    Paul
    I see. Did you try their GL4 oil or just the Severe Gear Oil?
    This is exactly what I needed to hear, thank you!
  5. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I tried the Severe Gear Oil yes. To Brian's point many have better luck with GL4. That was my next step if the Spirax did not work well, works great for me, other cars may experience it different. That's true with most oils so it seems.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,999
    Central NJ
    Dominick
    Get ravenol vsg and be done
    JLF likes this.
  7. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,454
    Los Angeles
    @Rifledriver Is there any particular GL-4 you like/recommend?
  8. Rifledriver
    37,246
    I usually use Redline MT90.
  9. Rifledriver
    37,246
    It is still a GL5.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,999
    Central NJ
    Dominick
    Agreed .. but it seems like it is a perfect match for our cars .. it works great in the 360 and the 430 so I figured it would work great in the 355 ?
  11. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    380
    NC
    I do wonder why it’s a perfect match for any of those? It’s still a GL5 and only touts “good compatibility with non ferrous materials” - no idea what “good” is?
    API GL4/5 standards say nothing about yellow metal compatibility. We just assume GL5 is not ideal because of the EP additives usually used don’t play nice with the brass synchros.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,999
    Central NJ
    Dominick
    Based how it is recommended / has approvals from a ton of manufacturers that have similar design (gear box and diff in one..including some high end cars) plus it does suggest that it is not going to hurt your soft metals. I always like to get what the manufacturer intended (spirax) and this comes the closest and easier to get. Besides working with some Ferrari owners that have used it and they all like the way it performs ..no chatter ..smooth shifting etc.
    Only time will tell with regular oil analysis to see if any thing happens.
    I understand why someone would choose a gl4 but based on how it is performing in some 430 and 360 so far this is what I choose
    Now if you were to tell me you were comparing gl4 to Mobil 1 sync gear oil ..then i would definitely use the gl4 in the "soft metal" gear boxes
    I used Mobil 1 sync gear oil in a 512tr with better results than shell approved "Ferrari oil" ..tf1055
  13. Rifledriver
    37,246
    I have used in in a couple of cars and found it good but unremarkable. However the lubrication needs of 360 and 430 are very different from 355.
  14. Rifledriver
    37,246
    I guess you have not been reading. And we know GL5 is hard on the brass syncros. I have yet another 360 here with all of the syncros trashed without a great many miles. Problem is their differential gears need GL5. It isn't a new subject to me. I have been studying it for a number of years.
  15. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,999
    Central NJ
    Dominick
    Thanks for the insight ..can you give me a few differences .. I always like knowledge TIA
  16. Rifledriver
    37,246
    Reread post 3.
  17. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,999
    Central NJ
    Dominick
    Ok ..got it ..the diff on the 360 is different than the 355 and for that matter the 512tr
    Thank you
  18. tstuli
    Jun 12, 2018
    380
    NC
    I dont quite understand your comment as I’m agreeing with you and the danger of gl5+brass.
    Anyways, Can you post photos of these synchros? Really interested to see what it’s doing to it.
  19. Skippr1999
    Skippr1999 F1 Rookie
    4,521
    Brian,
    Hope you've been well.
    I've been following this for years and appreciate the feedback you've given.
    With the research and observation you've done over the years what do you think is the solution at this point in time for the 360 ?
    Thanks,
    Skipp
  20. Rifledriver
    37,246
    I wish oil companies would be a little more honest in their advertising. I know GL5s have many different chemical make ups and Ferrari with their rather undersize and highly stressed hypoid diffs need it yet some are attacking brass. I do not believe all are but we just do not know. Rating any GL5 as GL4 and 5 is just BS. It completely ignores a very important attribute of the GL4 spec. I have a great big box of 360, 550 etc syncros that are destroyed and the damage is picture perfect for the failure attributed to GL5 damage. Very few cars have transaxles with brass syncros and hypoid diffs so no one really cares. In the old iron syncro cars it inhibited good shifting but rarely caused damage. As is there really isn't a solution
    Skippr1999 likes this.
  21. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,999
    Central NJ
    Dominick
    So getting back to my recommendation.. Ravenol seems safe to use in the 360 and 430 based on manufacturer literature..be curious which oil was used in the failed transmission.. like i would guess a Mobil 1 sync gear oil could cause that but a Ravenol and or a Eni rotra lsx wouldn't
  22. Rifledriver
    37,246
    What possible evidence do you have for that wild conclusion?
  23. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,999
    Central NJ
    Dominick
    #23 flash32, Aug 2, 2022
    Just based on manufacturer literature.. that is why I would love to hear which oil was used in the failed transmission
    Also I have a few people monitoring oil analysis if that helps
    Other then the manufacturer literature, oil analysis and the real life reason for sync break down (which oil) what else can someone go by
    I also believe red line makes that claim as well - brass safe
    So as i mentioned if we can see which oil was used in the various transmission you are rebuilding ..it may give us a clue ..
    Additionally - Mobil 1 sys not to use/ does not recommend in a manual transmission ..
    So that's how I came up with my recommendation .. but , as you will say, that my recommendations are only based on the info i can get from manufacturers and so far no one using Ravenol in my circle has had sync failure ( doesn't mean much ..small time and sample)
  24. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  25. PaulK
    PaulK F1 Rookie
    4,789
    Michigan
    Paul
