An EASIER way to do suspension bushings | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Birdman, Feb 25, 2005.
  1. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Hi Paul,
    Thanks!
    No lip. Not sure what pic looks that way, but no, there isn't a lip or a burr.
    Honestly, I can't tell the difference. I'm sure some people under some circumstances can, but I can't.
    Not me, and if they did squeak, I doubt I could hear it over the engine.
    I'm not exactly sure which parts do the rotating. When you bolt 'er down, the brackets clamp the inner metal "tube" of the bushing so it can't turn. Probably, it pivots on the mounting bolt itself. The OEM ones pivot on the rubber, which is why it is glued inside the bushing and the reason you need to torque them with the car on the ground and the suspension loaded. The poly ones don't do that.
  2. f355spider
    f355spider F1 World Champ
    18,031
    They can and do squeak, but are supposedly much improved with the graphite in the poly mix, and the newer greases. That is why I have been asking; what happens if the grease washes out or works out after a year or two?....I cannot live with spraying silicone frequently to keep the noise down. Here in the NW it rains often, so the silicone or oil will wash out easily.
    That is why I posted about using "anti-seize" over the supplied grease, because it is VERY tacky, and I would presume, even longer lasting...
  3. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I have been running Polygraphite bushings in my 240 for 4 years (daily driver). Aside from the initial lube during assembly I have not heard a peep out of them and they have required no additional lube.
    Everything is press fit (or nearly so) and if water IS getting in the bushings then you have a more serious problem them squeeky noises.
  4. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Dave-
    Have you ever gotten your hands on the grease that comes with the ES bushings? It is REALLY REALLY sticky. The first time I used it I was thinking it was adhesive! I can't imagine it washing out. I have an extra tube of it if you want me to send you one to check out.
    Birdman
  5. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    Birdman...the rear A-arms have bushings on outer part of the arm as well, do the ES bushing part numbers you used work for this application as well, or are these different bushings?
    Awesome writeup by the way...YOU ROCK!
  6. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Let me add that I have a small tub of silicone grease that has the same properties. It feels like contact cement coming out but once on the part is a good lubricant. Impervious to water also (used by plumbers).
  7. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Greg,
    The 308 has metal outer bushings absolutely nothing like the inner ones, and the only source appears to be Ferrari. However, they are pretty tough to wear out. The Mondial has rubber ones that *appear* to be the same as the inner bushings, but that is based on appearance and measuring the outside diameter, not on any research into part numbers or other technical research. I'm pretty sure they are the same, but not 100%
    Birdman
  8. senna21
    senna21 F1 Rookie
    Jul 2, 2004
    3,334
    Los Angeles, CA
    Charles W
    As a note:
    If you do not have a press or are unable to run to a machine shop you can just use a gas soldering torch to burn out the rubber.
    I used to have a (as Spasso has now) 240Z and used this method to replace my old bushings with urethane.
    It's dirty (lots of black smoke) and you need to be careful but once the rubber starts to burn it'll begin to fall apart in pieces and you'll be able to get it out without any problems. It takes longer than the press method though. Make sure you have a good set of gloves. I used my old Stand 21-3 layer nomex and had no problems (full nomex not just leather on the palms).
    I had no damage to the suspension arms what so ever. The original paint/power coating (or whatever Datsun used) didn't even bubble up. That I was surprised at!
  9. dave80gtsi
    dave80gtsi Formula 3
    1,905
    Ohio
    Dave Meredith
    Excellent info here, guys - a 'keeper' for sure!
    But, the original posting sort of begs a question - The operation shown is for the -REAR- A-arms.
    What about the front ones? While I suspect that the work will be similar in nature, wouldn't the fronts use a different bushing part no.? Or, are the front and the rears the same part, so that the identical bushing does double duty for both?
    Cheers - DM
  10. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    The 3x8s use the same ES bushings for front & rear inner a-arm bushings.
    The OEM bushings have different p/ns for front vs rear, it seems to be the firmness of the rubber. I can't rememer if the Mondials use the same front bushings also. Check the part #s at the ferrari.uk site.
  11. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Sheesh! You guys want everything! ;)
    I'm on a "need to fix" basis here! LOL! If the fronts ain't broken, I'm not messin' with them!
    That's a homework assignment for someone else!
    Birdman
  12. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Birdman,
    I just finished replacing my beloved 308's front and rear bushings. It was a lot of work, as you know. I broke a big vise, I fumed, I learned a lot.
    I was a service manager off and on for 10 years and one of the things that i always admired and respected was the mechanics looking for a way to save a bit or a lot of time in doing his work. I respected that, a sense of self worth, of customers' dollars spent, the drive to do the job in a shorter time.
    I see a bit of heat coming down and i want to step in to juistify expedient work. We all must work within a budget. If we are personally wiling to do what ever it takes to do a perfect restoration/upgrade, or pay to have it done, that's cool.
    But if we also have many other "issues" to deal with, we may need to consider some of the more creative approaches.
    I have had a few too many beers to ponder this more deeply, but will take it under advisement
    I salute you and your many past repair discussions.
    your bud,
    chris
  13. f355spider
    18,031
    I had a complete set for my 308/328, but never installed them....sold them recently...never popped one of the tubes open...thanks, good to know...the stuff "looked" like plain silicone type grease. Sounds like much better than that!
  14. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    This is a good thread Birdman, well done.
    Ok, Ferrari actually supply and specify a different hardness bush for the front to the rear for 308. They have different part numbers but are the same size. In real life though, just use the hard ones all round, as you'll not notice any degradation in ride quality by using hard ones where soft ones are supposed to be, in fact, quite the opposite.
    www.superformance.co.uk supply both hard and soft replacements, for about 11.5 GBP each. I use these and have no trouble with them, fitting is a breeze with a home mig welder too, so although a press is handy at home, I'd argue a mig welder has more value, so if you can run to it, buy that, or why not both!!
    The outer rear for the 308 (and inner for things like 400/365BB/Daytona etc) is solid. It is called a "DU" bush by me, as that is what the local bearing supplier terms the teflon sleeve insert and ring thrust washer that is easily and cheaply available. The chromed tube is a Ferrari specific part though, but this tends to outlast the car in most cases.
  15. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Phil,
    Thanks man!
    Also, thanks for the clarification on the front/rear bushings on the 308. That has been something a lot of us have been wondering about (i.e. why the bushings appear to be the same, but have different part numbers!)
    Birdman
  16. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Birdman - excellent post. I am undertaking the full restoration and have cut out the existing bushings, and pressed in new ones.
    One observation that I stumbled upon is that when chemically stripped (dipped), the rubber goes to the great wasteland in the sky. When I took my 8 A-arms to the stripper, I had not yet removed 4 of the bushings. When I got them back, the two A-arms that still had bushings in them now were rattlling. The inner bushing was loose within the outer bushing, the rubber was no where to be found. It would be a snap at that point to cut out the inner bush-tube as your suggested. In addition, you now can paint or powder coat the A-arm (masking the bushing tube if so desired).
    Just another observation to add to your (Birdman's) treasure chest.
    Jim S.
  17. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Jim,
    VERY cool to know! For sure, the next time I undertake a strip of the A arms I will send them out to be dipped because sandblasting them was a HUGE pain!
    Birdman
  18. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    "I respect your opinion. When I did my 308, we went overboard, sand blasted and powder-coated the A arms, etc"
    IMHO, you did not go overboard, You did a top notch job!
    "Guess what? Nobody can see them and knows they are powder coated except me"
    You are wrong there, everyone who has looked at that thread knows how much time and effort you put into that job!
    The same way that everyone that has looked at this thread has seen these A-arms, hundreds of people.
    "I didn't refer to your suspension rebuild as half-assed because you ONLY painted yours, and didn't actually go the extra mile and powder coat them"
    I own the same powder coater that you used for your A-arms,
    and tests showed that the black powder I purchased was not resistant to brake fluid.
    All of the A-arms on my 308 have been re-painted once more with VHT epoxy paint which was resistant to brake fluid.
    Good Luck with the new ride!
  19. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Hey Dave,
    You actually TESTED the powder coat stuff against the paint with brake fluid? Wow. Talk about thorough! You should fix those leaky calipers though! ;)
    I'm really surprised that a paint would be better than powdercoat at anything. I tried to sandblast a part that we powdercoated and it was as tough as iron. I couldn't get the powdercoat off it.
    No doubt, I agree with you, if I were in this as a full suspension overhaul, I would clean and repaint or powdercoat the components. I have a roster full of service to get done before spring so we can drive this car, and my goal was to fix the bad bushings and move on to the next thing! Now thousands of Fchatters know what a hacker I am!!! AHHH!
    Birdman
  20. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    I'm of the opinion that this is the way to go, I'm glad to see you proved it to work. It keeps more of Enzo's blessed Iron in the car, rather than something dug out of the ground after he was in it. ;)
  21. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    There are 3 different kinds of powdercoat. The polyester based ones probably won't stand up long to brake fluid or lacquer thinner. Suspect that's what you tested.
    However, the epoxy and probably the hybrid powders should stand up to just about any solvent.
  22. jwise
    jwise Formula Junior
    Apr 2, 2003
    781
    Portland Maine
    Birdman- Great post! Thanks for writting it up. These are the types of posts that make FChat a great community.
    Now I know how I'll do my bushings when the time comes. (Probably sooner than later)
  23. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Hey John,
    You're welcome. I have a feeling a lot more people might undertake this job now that they don't need to deal with grinding and welding.
    Bring your car here when the time comes and we can do it on my lift. (I figure Verell is probably tired of seeing your car on his lift! LOL!) Actually, now that I think of it, I actually own ONE tool that Verell doesn't have now! (The hydraulic press). Given the fact that Verell has virtually every tool in the known universe, this is quite a feat. However, I think Verell's arbor press would probably take the bushing guts out just fine.
    Birdman
  24. geekstreet
    geekstreet Karting
    Feb 7, 2005
    220
    Cam
    Sorry I'm too lazy to check this on prev threads, but I take it the agreed opinion is that installing urethane bushings does NOT cause the ride & bump handling to deteriorate into harshness? If not, then this has GOT to be the way to go. Thanks Birdman.
  25. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    Bird man you said at the beginning of the post that this was a rear A arm job.Can the same process be done with the Front A arms?.Thanks in advance
