An "UH OH" sound in engine bat | FerrariChat
Discussion in '348/355' started by wrk2ownCT, Oct 6, 2014.
  1. wrk2ownCT
    wrk2ownCT Karting
    Nov 30, 2012
    134
    Madison CT
    Chris
    So I started my 355 Sunday (sorta chilly) and from the engine bay closest to the large cogs in front of engine was a clankety-clank sound very pronounced and rhythmic.
    If you revved the engine a little it would go away until idle return, and once engine hot it was gone.. Early thought was timing belt but it was done 5k miles ago after huge engine rebuild (guides, liners, new belts, bearings)
    Is it likely the timing belt already!?! FML I can't bear another engine out after spending 28k in work to get her redone just a couple years ago..
    Please advise this newish owner.
    Chris~
  2. bosshog8
    bosshog8 Formula Junior
    Mar 13, 2011
    448
    Pinelands NJ
    Demetrius
    All you can do is check the spinning stuff that is not connected to the timing belts, i.e. alternator, tensioner, A/C, etc. If you don't find anything then you have to look deeper, what ever that entails. There are plenty of things on the front of that engine it could be.
  3. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,963
    The Cold North
    Tom
    When you did the belts, did you check the condition of the tensioners? (Not the roller, but actual tensioner) and were they set correctly.
  4. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    I had a similar thing on my 355
    Turned out it was the flange that holds the silver firewall to the bulkhead.
    Nut had come loose and the flange was rubbing against a pulley wheel.
    Bent it back out of the way.
  5. schefdeh5
    schefdeh5 Formula 3
    Nov 2, 2008
    1,529
    U.S.A.
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,241
    CT
    John Kreskovsky
    Have to ask, what did you spend 28k on and who did the work.
    Really impossible to diagnose anything by saying it goes "clankety-clank". My car makes noises that I could call that and they are normal. There is a lot of valve noise and it could just be the lifters pumping up when cold.
    BYW, I see you are in Madison. I'm in Marlborough. Have you ever considered coming up the Sunday Gathering in Glastonbury? See the on going gathering thread in the New England forum.
  7. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    My Indy mech has a special "tool" to locate strange noises. A three foot piece of hose slightly larger than a pencil ..... One end in the ear and the other touching suspect areas. I had a clicking noise at low rpm that was getting louder and louder, it was driving me nuts, he figured it out in about 1-2 minutes, leaking exhaust gasket.
    Getting access in the front of the engine may be difficult, take the May out of that ..... Will be.
  8. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    A good, and long time Ferrari shop has probably seen and heard this before. Also, an indy is probably better than "real" Ferrari shop since they see most of our older cars.
  9. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,014
    PA
    Kevin
    It is likely the hydrostatic tensioners. Do a search on the word hydrostatic.
  10. WATSON
    23,710
    WI
  11. mtl360
    mtl360 Rookie
    Mar 4, 2012
    45
    Montreal, CANADA
    I am actually experiencing this as well in my 98 355 spider....would be curious to know what it is
  12. Eric C
    Eric C F1 World Champ
    11,085
    St. Louis, MO
    Eric
    Read the link Watson posted.
  13. cuneo
    cuneo Formula 3
    2,472
    Same thing on my 95 355 B occasionally, especially when sitting dormant for a week or more which is rare for me. There are a lot of spinning things up there, and as said earlier it probably isn't anything to get your panties in a bunch over in my non-expert opinion. Get it looked at by your mech.
    Your title made me think you had an engine compartment-dwelling flying pet rodent that was having digestion problems or something... ;)
  14. mtl360
    mtl360 Rookie
    Mar 4, 2012
    45
    Montreal, CANADA
    Watson's link takes me to a post about a TV show on PBS
  15. WATSON
    23,710
    WI
    Just checked it....it goes to a link about the noise you desciribe and the solution.
  16. Eric C
    11,085
    St. Louis, MO
    Eric
    Ha! What?
  17. WATSON
    23,710
    WI
    Hey....at least it wasn't some porn site! :) :) :)
  18. mtl360
    mtl360 Rookie
    Mar 4, 2012
    45
    Montreal, CANADA
    Ok, now the link takes me to a proper thread, thx :)
  19. Turbo Ron
    Turbo Ron Formula Junior
    Nov 3, 2003
    262
    West Los Angeles, CA
    Ron Stavis
    Chris, I sent you a pm.
