Angel eayes 430. Take a look. | Page 11 | FerrariChat
Discussion in '360/430' started by lilleprins, Oct 28, 2010.
  1. BentleyKWT
    BentleyKWT Karting
    Jun 15, 2011
    134
    Kuwait
    Bentley KWT
    Guys,
    I would like to point out a few things.
    The are different types of LED's, Those include 1w,2w,3w Diodes. Also there are different manufacturers. Cree is one of the best diode manufacturer. The ONLY good ones from china are EPISTAR LED DIODES .
    I suggest you guys order CREE 1W diodes and use those instead. It will be twice as bright, and will last FOREVER.
    1w diodes will not heat up.
    GOOD LUCK
  2. UH-Matt
    UH-Matt Karting
    Mar 31, 2011
    95
    Thanks for the input, is there links to places online where CREE LED strips can be purchased suitable for this task?
    I bought some cheap ebay ones here in the UK today, will let you know how I get on with them..
  3. BentleyKWT
    BentleyKWT Karting
    Jun 15, 2011
    134
    Kuwait
    Bentley KWT
    Hej!
    EPISTAR is the only good Chinese Led Manufacturer. Cree is the one of the best in the world, from the U.S.
    How many watts are your diodes? For example If you have a TRUE 1w diode it should only be run at .8 watts, or else it will get too hot and burn out very soon.
    Chines L.E.D are over rated, meaning they rate a 1w at 2w and run it 1w, resulting in the heat problems and burnout.
    Hope this helps. So getting a good quality Diode is very important
    Ferrari can lean a thing or 2 from you
    TACK!
  4. BentleyKWT
    BentleyKWT Karting
    Jun 15, 2011
    134
    Kuwait
    Bentley KWT
  5. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    Thanks very much for the additional info.
    I agree that 1W led may hold up much better but then we have another problem: draining too much current. Imagine 50 X 1 W led strip = 4,2 Amp * 2 = 8,4 Amp...that already more than the stock light bulbs and then the position light fuse won't hold.
    My goal of this mod was to reduce considerably the drained current compared to the light bulbs so that I can use the P switch when parked for hours without draining too much current from the battery. Those I installed now do not drain any current at all, only 128mA/1.5W per each strip. Being of more classic LED technology (no operating heating at all) compared to the SMD5050, they should hold up forever. Will see with the time ;)
  6. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    Those are identical to the strips I have installed. So yes, you can go for it ;)
  7. BentleyKWT
    BentleyKWT Karting
    Jun 15, 2011
    134
    Kuwait
    Bentley KWT
    You would not need the many LED'S if you use the 1 watt Diodes. I would say 5 for every side. I would also color match the LED color to the Exterior color. That might turn out to be afail. I think on a RED or BLUE 430, it would be great.
  8. ant818
    ant818 Rookie
    Oct 25, 2009
    5
    long island, NY
    i just read all 13 pages of posts. Has anyone put together a kit for sale?
    Anyone know where to get the strips in the US?
  9. BentleyKWT
    BentleyKWT Karting
    Jun 15, 2011
    134
    Kuwait
    Bentley KWT
    There is no kit. It is very simple. It is just a LED strip.
    They sell them in Ikea or you order online.
  10. UH-Matt
    UH-Matt Karting
    Mar 31, 2011
    95
    Just type into ebay.com "48 LED White strip" and you will find nearly 1,300 results - find the whitest nicest looking ones you can and buy them, 2 sets about $5 cost!
    This one is on auction for $0.99p and ends in 18 hours if you want to be super cheap...
    http://cgi.ebay.com/ebaymotors/2-x-48cm-48-LED-Headlight-Strips-Light-4-Audi-R8-White-_W0QQcmdZViewItemQQhashZitem19c6500f0dQQitemZ110701317901QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    Then you need 2 bulb holders and some soldering experience, or someone to do that bit for you.
  11. BentleyKWT
    BentleyKWT Karting
    Jun 15, 2011
    134
    Kuwait
    Bentley KWT
    If a strip cost 5$ dollars, I warn you, They are probably not LED diodes, just three small bulbs made to look like a LED diode, maybe Halogen Metal Halide.
    Don't say I did not warn you. A real LED will cost you money. Usually a atleast dollar a Diode, anything less, You should start asking questions.
  12. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    That's what I've paid and they are real LEDss. LEDs as separated componants are very cheap and cost only a couple of cents.
  13. F430addict
    F430addict F1 Rookie
    Sep 17, 2010
    4,460
    Agreed. These things cost almost close to nothing.
  14. BentleyKWT
    BentleyKWT Karting
    Jun 15, 2011
    134
    Kuwait
    Bentley KWT
    #264 BentleyKWT, Jun 16, 2011
    I just checked your light and realized you are running 1.5w per side. I was under the impression you guys were using much more. So I was way off in my last post. Considering the wattage, you can definitely run them for that price.
    I have used LED's for a different application, and I build a light using 200 1 watt diodes. It cost me about 700$ for the LED's
    $700/$200 = $3.5 per watt
    at 3 watts(based on the Power you are using) it would be $10.5 dollars. So, I was definitely wrong in advising against it. Although, I do beleive you can get a brighter longer lasting diode through a better company. Apologize for steering you guys in the wrong direction.
    I think this modification is amazing and am considering doing this to my Continental GT.
  15. F430addict
    Sep 17, 2010
    4,460
    Truer words cannot be said. Go for it!
  16. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    #266 SfefVan, Jun 17, 2011
    Thanks for correcting. You started seriously worring the guys here :) ! Although, I don't understand your calculation logic between money and watts...weird.
  17. UH-Matt
    UH-Matt Karting
    Mar 31, 2011
    95
    Definitely thanks for correcting. When spending $10 on a mod for a $130,000 car I definitely like to know I am doing it right ;)
  18. UH-Matt
    UH-Matt Karting
    Mar 31, 2011
    95
    #268 UH-Matt, Jun 20, 2011
  19. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    Thanks for posting your pictures. They are 100% simular to mine.
    Except if one is looking for the Audi style LED's (which is definitely NOT my case), these LED's are just bright enough at daylight and very good at night. I have been driving now a good 3000 km - 1800 miles with them and they are just perfect, no issues, no heating, drain no current and I can leave them on when parked at night on a busy road without worrying about the battery (but then I advise you to do also the tail light DIY guide :) )
  20. roose369
    roose369 Rookie
    Nov 14, 2009
    15
    Chile
    Joachim Roosen
    Hi,
    On my 360 the interior of the frontlights are fogged and need cleaning or polishing, is the way to extract the same as on the 430 ?
    Joachim
  21. UH-Matt
    UH-Matt Karting
    Mar 31, 2011
    95
    Unfortunately I broke one of my LED strings being a bit heavy handed, got in a mood with it and gave up after finishing one of the sides... gone back to bulbs for now.
    Someone else on another forum also said if you have ANY electrical issues and Ferrari see these in the car then they will probably try and wriggle out of any warranty claims - I have 2 years left on my car so decided not to do the mod. :(
  22. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    Sorry to hear that. Maybe one day, you'll give it another try. Just make slow moves without forcing. It should get in the tunnel easily.
    I'm not sure this mod would affect your warranty but if you have doubts, just leave your car stock and in 2 years you'll enjoy your freedom :)
  23. RichardCH
    RichardCH F1 Rookie
    4,661
    So th question is who makes Audi LEDs ?
  24. ASFJr
    ASFJr Formula Junior
    Oct 11, 2004
    499
    SF, CA & NYC, NY
    Alfonso Faustino
    Many thanks to lilleprins and all that contributed to this thread. My technician, TAFORZA did the LEDs on my F-430 Spyder three pedal, which I named, Saphira.
    I am so happy with the results. He also created a metal brace so endure the string of LEDs don't shift or move due to heat expansion. All wires and sockets are in tact in the event that I want to replace the original 1.5 watt, which I doubt I ever will.
    Here is the pictures I posted on the following FerraiChat Thread: http://ferrarichat.com/forum/showthread.php?p=140647393#post140647393
    All of you are awesome! Thank you!!!
    Check 6.
    /s/ Alfonso Faustino
  25. F430addict
    Sep 17, 2010
    4,460
