Annoying 308 door problem | FerrariChat
Discussion in 'Technical Q&A' started by newark_308, Jan 22, 2005.
  1. newark_308
    newark_308 Karting
    213
    Newark DE
    Glenn Frenck
    The driver side door on my 308 won't close flush, it springs back about .25". I don't want to just attribute it to the cold weather for the last week. I've checked the mechanism and it moves freely and there isn't any junk where the pin goes. The door mechanicsm is working and is required to open the door. Any ideas???
    Glenn
  2. thecarreaper
    thecarreaper F1 World Champ
    18,159
    Savannah
    my passenger side door was hard to open when i got the car, the drivers side did what yours is doing now. i cleaned and lubricated the linkage, latch and striker assemblies and all is well now.
  3. bearduke1
    bearduke1 Rookie
    Oct 19, 2004
    26
    South Carolina
    Bubba Joe
    On mine, the new weather seal on the removable top puts pressure on the top of the window and tends to spring the door out a bit unless you close it somewhat strongly.
  4. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    I suggest following reaper's advice--mine started doing that, too, just before it began popping up open all by itself, and not re-latching!
    I pulled the door panel off, squirted a lot of Slick 50 One Lube (Tri-Flow would be good, too) on all the exposed parts of the mechanism and it got all buttery-smooth. The old lube gets too thick, especially when it's cold(!), and keeps the rotary latch from rotating far enough fast enough to latch properly.
  5. Morrie
    Morrie Karting
    Nov 4, 2003
    207
    Sarasota/Asheville
    Check the weather seal that runs down the side of the windshield at about a 45 degree angle. They sometimes slide down and get into the door jamb causing the door to be hard to close or pop open.
  6. rimoore
    rimoore Formula 3
    Nov 18, 2004
    1,353
    Island in Maine
    Richard Moore
    I had the same problem. I adjusted the pin that's connected to the body of the car and it solved it.
    Rick
