Having an issue here with my 2008 599 GTB. Having previously had actuator issues (which was replaced) i now have another issue. Car has been laid up over winter having cam sensors replaced and a few other bits and bobs, car was put back together and was running smoothly, went off for a test drive and was fine. When they went to then move it it was having issues - found out there was air in system, fixed, then the pump wasn't pressurizing right, so replaced that, now it wont learn through the SD process, can get it to work through 1-4, but wont select 5,6 and R. We're looking to swap out the ECU with another to see if that resolves but any thoughts from the experts ?? Regards Hughesie
Hi Justin, given your location I would highly recommend Bob Houghton. I would probably recommend them no matter where you are in the UK.
Cheers, I am using a specialist recommended by Ashley Piper a well know Ferrari specialist so think I'm in good hands but will bear that in mind.
