355 - Annoying Brake Squeak just prior to Stopping | FerrariChat
355 Annoying Brake Squeak just prior to Stopping
Discussion in '348/355' started by Laserman, Oct 2, 2020.
  1. Laserman
    Laserman Karting
    Oct 26, 2018
    113
    Minneapolis, MN
    I have an annoying brake squeak that occurs in the last instant before the vehicle come to a complete stop.
    It does not happen when the brake are dead cold. They seem to need to warm up a bit before it starts happening.
    I have checked all four calipers for lining and all of them have plenty of life left.
    Where should I look next.
  2. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    761
    Vermont
    john truskowski
    There are many threads on this subject. The cause is the metallic pads that are squealing. Many folks here have found that changing the pads to Porterfield brand fixes it. Mine were squealing and it didn't seem to be getting any better so I ordered the Porterfields and soon after arriving the squealing stopped. They are still sitting in my garage awaiting installation. Another stopgap that you can do is to get the car up to speed in a safe area and do a few hard stops to heat up the pads and get some of the metallic material really hot. That will (sometimes) stop the squeal, but it may come back. Or you can just order the Porterfields and put them in your garage. :) Good luck.
  3. Laserman
    Laserman Karting
    Oct 26, 2018
    113
    Minneapolis, MN
    Thanks, I will have to try this this weekend.
  4. WATSON
    23,798
    WI
    Back the car up at some decent speed and apply the brakes. Do this a couple of times.
    Brembo and others have an anti-squeal paste to apply to the back of the pads / shims.
    I have to apply the paste to the pads about every three years. I am due.
  5. jdlegg
    jdlegg Formula Junior
    Dec 22, 2009
    253
    San Rafael, CA
    James D
    Bedding the brakes will help. So will regular rinsing (when cold) of the brake dust. Every Ferrari & AMG I've owned has had squeaky brakes from time to time. Gives you an excuse to go wash it! :)
  6. tres55
    tres55 F1 Rookie
    3,572
    Canada
    You can swap to a semi metallic compound brake pad for street driving.
  7. m.stojanovic
    m.stojanovic F1 Rookie
    3,287
    Serbia - Niš
    Miroljub Stojanovic
    Sometimes, pads get glazed. You can try roughening them a bit over a sheet of course sandpaper (placed on a flat surface) and see if it eliminates the squeak.
  8. ClydeM
    ClydeM F1 World Champ
    11,999
    Wayne, NJ
    Clyde E. McMurdy
  9. harleyx49
    harleyx49 Karting
    Jun 26, 2013
    122
    Hutchinson, MN
    Also had embarrassing squeals on my 348 even though the Brembos look fine.
    Had member Tim "2NA" replace them with Porterfields a few years back and since have not had another squeal.
