Annoying Glove box squeak | FerrariChat
Discussion in '456/550/575' started by TAT, Mar 15, 2011.
  1. TAT
    TAT Rookie
    Feb 4, 2011
    17
    Gold Canyon Arizona
    Thomas Tutsch
    I have an annoying glove box squeak on my 575SA. I assume that it is the same as other 575s. I have already given the hinge mechanism a shot of silicon lube. Any ideas?
  2. maranello72
    maranello72 Formula Junior
    Jul 4, 2009
    354
    Munich, Germany
    Stefano
    Are you sure it's the glove box?
    My 550 sounded like a hamseter was trapped in there, and it turned out to be the fuse box's lid under the passenger's carpet. One of its fasteners was not closed properly.
    Stefano
  3. tazandjan
    39,170
    Thomas- Mine does not squeak that I can hear.
    Taz
    Terry Phillips
  4. Norm512TR
    Norm512TR Formula Junior
    Nov 10, 2001
    895
    Colorado Springs, Colorado
    Norm
    A good exhaust will cure most squeaks
    norm
  5. sf_hombre
    sf_hombre Formula 3
    1,353
    Stimulus Bill
    Don
    Nope, no squeaks for me either.
  6. Kenny94945
    Kenny94945 Karting
    Nov 1, 2003
    230
    Marin Calif
    You could try to place a little piece of felt (or two) between the glove box door and the glove box compartment lip to see if the squeek stops. If so, then make a permanent felt installation...nice round circles for example.
  7. TAFORZA
    TAFORZA Formula Junior
    Jun 5, 2008
    296
    San Francisco, USA
    Tony A.
    First you need to make sure that the noise is actually coming from the glove box. Many squeaking noises that happen on the outside of the car such as "bushing noises" will feel as if they are inside and coming from that area. Try pushing slowly up and down on the fender to simualte a bumpy road and cause the suspesnion to move, and listen for any noises on that side. We have had many situations with bushing noises that the customers thought are coming from inside the car. Good luck
  8. drabe
    drabe Karting
    May 29, 2010
    143
    I had a squeak coming from that area which turned out to be a loose piece of trim along the lower part of the windshield outside of the car.
  9. TAT
    TAT Rookie
    Feb 4, 2011
    17
    Gold Canyon Arizona
    Thomas Tutsch
    If I press on the glove box door, it stops. If I put in a felt bit it continues. Thanks for the ideas
