355 - Annual Maintenance Routine | FerrariChat
355 Annual Maintenance Routine
Discussion in '348/355' started by Oz-ATL, Mar 1, 2022.
  1. Oz-ATL
    Oz-ATL Formula Junior
    652
    What are you guys doing for annual maintenance on your 355's? oil and filters? more? based on mileage or time (or bit of both?)
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  3. bcar1
    bcar1 Karting
    Aug 2, 2017
    224
    NYC
    Bob
    Bradan does
    Engine oil/filter
    gearbox oil
    coolant
    brake fluid
    Not doing the coolant apparently leads to premature gearbox oil/coolant heat exchanger failure.
    Shorn355 likes this.
  4. Shorn355
    Shorn355 F1 Veteran
    6,859
    Colorado
    Scott
    I do annual/bi-annual/annual/major- repeat- Religiously- based on time regardless of miles.
    I can find/post the work orders for both annual and bi-annual if that would be helpful.
    Pretty much as/what you stated - I do the brake fluid on the bi-annuals.
    Cheers :)
    Mike Morrissey likes this.
  5. Shorn355
    Shorn355 F1 Veteran
    6,859
    Colorado
    Scott
    As promised, here are the Annual and Bi-Annual invoices from my local Dealer for my 1995 355 GTS - Hope this helps - Cheers :)
    ConnecticutGent likes this.
  6. Oz-ATL
    652
    Great responses, much appreciated gents. I like the coolant swap addition.
    @Shorn355 - great info!
    Here is a list I've also seen for a typical annual on a 355:
    1. Replace Engine Oil and Filters with new gaskets
    2. Replace Brake Fluid
    3. External and Internal Visual Brake Inspection – Pads and Discs
    4. Inspect Air Filters and Replace if Necessary
    5. Inspect Pollen Filters and Replace
    6. Top off Power-Steering fluid and Washer Reservoir to Correct Level
    7. Visual Inspection for any apparent leaks
    8. Check Front and Rear Suspension Components
    9. Visual Inspection of Fasteners and Bushings
    10. Check Tightness of Engine and Transmission Fasteners
    11. Visual Inspection of Wipers and Replace if Necessary
  7. A348W
    A348W Formula 3
    Jun 28, 2017
    1,846
    North Wiltshire, UK
    didnt think the 355 had a pollen filter?
    in addition to the above mine does a four wheel alignment check.
    SalF355 likes this.
  8. Oz-ATL
    652
    I just swapped them out in my 993 so wasn't sure if the 355 had one or not. Looks like not.
  9. Qavion
    Qavion F1 World Champ
    14,262
    Ian Riddell
    Oz-ATL likes this.
  10. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I answered but then I saw you said "Annual" maintenance...:eek::p
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    Oil, filter, gear box oil, coolant, brake fluid
  12. Drock28
    Drock28 Formula 3
    Jan 13, 2013
    1,430
    Montreal
    Tony
    weekly service: drive, drive hard, drive, drive hard= no problems, car says thank you non-verbally
    Annual= oil change
    monthly check oil level.
    2-3 years: transmission oil
    6-7 years: engine out.
  13. yelcab
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    And only change your coolant and brake fluids at the 7 year major? I am not sure that is the best advice for a 355.
  14. Skippr1999
    Skippr1999 F1 Rookie
    4,507
    #14 Skippr1999, Mar 5, 2022
    Depends on the kind of coolant. Extended life,etc.
    if the BMW and Mercedes coolants are rated for 15 years, it surely can make it 7.
    my excellent mechanic laughs at the excessive fluid service intervals discussed on here.
    Targatime and johnk... like this.
  15. 26street
    26street Formula Junior
    Jan 30, 2021
    466
    Westchester New York
    Mark k
    Oil and filters (oil air and fuel)
    Brake fluid flush
    Check antifreeze PH every 6 months and adjust flush and refilled 2 years
    Transmission and gear check and replaced every 2 years (synthetic oil and lube used only)
    Complete check of all safety items brakes, steering, suspension, lights etc
    Then drive, drive and drive more —- like any good stallion they are happy when they stretch their legs a lot——
  16. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,683
    LA & OKC
    Kevin
    I drive it really hard until something breaks, then I take it in open wallet to a trusted mechanic and do everything he recommends.
    26street likes this.
  17. yelcab
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    You would be a good customer.
  18. Shorn355
    Shorn355 F1 Veteran
    6,859
    Colorado
    Scott
    Glad the invoice screenshots were helpful- Cheers :)
    Another place to start/refer to is N6 - N10 in the Ferrari owners manual (available in PDF if you don't have the physical one) since Ferrari designed, engineered and built the car, Ferrari might have some decent insight as to the recommended maintenance schedule.
    :cool:
