Another (348) brake question | FerrariChat
Discussion in 'Technical Q&A' started by NC348, Jul 24, 2004.
  1. NC348
    NC348 Karting
    Feb 18, 2003
    154
    Houston, TX
    James I. Movich
    when bleeding the brakes, what is the process?
    am i supposed to have the key on or something during the bleeding? the book is confusing. it says just like regular and then refers to having the pump on...
    can someone please take a minute and explain this to me.
  2. NC348
    NC348 Karting
    Feb 18, 2003
    154
    Houston, TX
    James I. Movich
    can some one help me out?
    i want to get this done maybe this weekend, and i am hesitant to begin without at least a little advise
  3. RAYMAN
    RAYMAN Formula Junior
    315
    Oklahoma
    Raymond Santilli
    Yeah I think you have to have the key on, or you'll have a dead pedal when you try and bleed. You'll find out when you get to that point.
  4. fatbillybob
    Aug 10, 2002
    29,293
    socal
    key on when you bleed.
    two man bleed it.
    some your bleed process when you hear the pump come on and continue when the pump is off.
    check fluid level frequently.
  5. NC348
    NC348 Karting
    Feb 18, 2003
    154
    Houston, TX
    James I. Movich
    and just to add more brake fluid to the fire...
    i agree these bleeder fittings are junk. they wiggled around so loose in threads they would suck air like crazy if you let them get too loose or a little crooked. i could tilt the fitting a little and watch a steady stream of bubbles form as the venturi effect was sucking in air from the sloppy tolerances. total
    POS.
