Another 348 gearbox takeapart... | FerrariChat
Discussion in '348/355' started by Marco Bussadori, Mar 22, 2009.
  1. Marco Bussadori
    Marco Bussadori Formula Junior
    Aug 6, 2007
    430
    London
    Marco Bussadori
    #1 Marco Bussadori, Mar 22, 2009
    I was lucky... For a 2 dollar part I could have lost the whole box.
    This is my spare gearbox. I took it apart as I needed to change the pin that drives the gearbox oil pump which was broken. To do this you need to take the oil pump side casing off, followed by the ring nuts and then the whole cage. This will then expose enough of the main shaft to get you to the little hole where the pin fits. To block the gears you need to remove the face place and engage the reverse and 2nd gears.
    I had to buy a GBP 70 ringnut tool from hill, 2 SKF BA2B 636151A's (GBP 90), 2 ringnuts (one left turning and one right turning), a tube of Locktite 271, and yes the pin for a single pound.
    Aside from being nutty irritated at the waste of a whole morning and 200 pounds to replace a tiny pin, I was very happy to find that the ringnuts were somewhat loose. At arm power I managed to tighten them by about 10 degrees of turn (then I found out I got them backwards and tightened instead of loosening.
    There was NO locktite anywhere, though the ringnuts were staked (but not very well I may add) - this was an October '93 box SN. 1416856915. The bearings in there were the later type - BA2B 636151A, matching the ones I had in "stock" perfectly (so I did not have to mess with the spacers) - so I took the liberty to replace the bearings. The original ones were perfect, so no problems to start with. The sealant was a white sealant, so I am assuming this box was not opened since manufacturing.
    Can someone tell me what the correct torque setting for the ring nuts should be? I don't have an impact wrench, but I can tell you I have enough strength to break a 25mm socket, so I must be good for some 400nm on the biceps... I'm going to drown them in locktite (which is best? red 271, or blue 243?)
    Nothing new, but here are some pics for anyone who needs them. P.S. the red "stain" is copper grease spray.
    Marco
  2. Philip Barnard-Browwn
    Feb 25, 2007
    168
    london.
    Philip Barnard-Brown
    Hi Marco, always love reading your threads.How long did it take you to complete the work on your gearbox? One of the jobs i have planned for my car is to give the gearbox a clean bill of health.
  3. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    It is about a day of bench time with all the necessary spares. A half day to take it out and a half day to put it back in ( buying you some spare time both ways). I'm in London too... I have a '90 and a '93 box at hand. I'd be happy to help you if you want. 2 people can do this in a garage with two bottle lifts and two stands. If you tell me the age of your box, and I could shift it cold & warm while listening, I can tell you if a) there is a reason to open it, and b) if the bearings or ringnuts need doing.
    So far none of the ringnuts have been pinged or loctited properly... Probable yours is in the same situation.
    Remember when loosening the ringnuts, that they have different threading. The frontmost (towards driver) shaft (lay shaft) loosens clockwise, the rearmost (towards the clutch) loosens anticlockwise. This is counter-rotational and designed to prevent the loosening of the ringnuts. (The same is true of the opposite side, but no need to take them out.)
    As I said, happy to help... my number is 0777 037 3029 and I am in west London (Ealing).
  4. Philip Barnard-Browwn
    Feb 25, 2007
    168
    london.
    Thanks Marco, I will give you a call if that's alright. Maybe the box is fine. Does change o'k. Only as the car is now 16 years old. 1993. Just want to make sure.
  5. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    Good thing is that the only major issues are the main-shaft bearing by the oil pump and the drop gear splines both due to poor tightening at the factory. The fist produces a marked whine as the bearing races wear, and the latter a clear clunk most noticed when in first gear and at walking pace you tap the throttle on and off - usually in start-stop traffic.
    The '93 box, I believe is the last generation of 348 gearboxes (the one in the pictures below is one of them) with all the improvements to deal with most of the early box issues.
    I'd be very happy to test yours and hear if it is something to worry about. We can pull the sump plug, and while it is drained pull the inspection plate for a look-see... You can then take advantage if this to refill with Redline Ultralight Shockproof gear oil. I can get it for you in Chiswick if you want.
    By definition I have a spare box that is available for anyone who wants to defend themselves from rip-off F-dealers. It is now completely refurbished and all the evidence is on-line ;-)
    You can call me anytime for a chat.
    Marco
  6. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Marco my man, that is one fine post, Stooge style!
  7. MaterMech
    MaterMech Formula Junior
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    Just wondering if the loctite is recommended on the outer races. How much of an interference fit is it? I've got the clunk and at 36K miles it's time for preventative maintenance. When you guys say drop gear what part are you referring to?
  8. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    It is the one you had a problem with when your gearbox seized. It is the clutch shaft and the bevel gear shaft. Those are connected by two gears, each fixed on by a ringnut. The one on the bevel gear is accessible by removing the small panel under the flange for the throwout bearing, the other requires the removal of the clutch shaft. The clutch shaft is hollow and has the prop shaft going theough it from the engine to the flywheel.
    It is all in your old post http://www.ferrarichat.com/forum/showthread.php?t=163194&highlight=splined+shaft.
    You can loctite the hell out of the geat onto the clutch shaft, then super tighten the ringnut. I have seen people actually weld the two parts together is the splines were too far gone. With the splines gone, both parts are throw aways anyway, so yo may try to do that. A good steel to steel weld can work wonders, but a bad one can misalign and ruin everything...
    Marco
  9. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Cool thread Marco! :):)
    I am looking forward to seeing what my bearings are like when I do my major. :):)
  10. Ricambi America
    Sponsor Owner
    #10 Ricambi America, Mar 26, 2009
    Stop driving. Now.
  11. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    MaterMec,
    You have a post where you took this part out as a result of a 400 ft burnout a week after you bought the car. The nut I am referring to above is the one that came loose on your shaft that caused it to move outwards and hit the throwout bearing flange. Did you just tighten it and put it back in without loctite? If so pull it back out, undimple the ringnut and you can try the below
    I don't remember the loctite number. 242 is medium strength. If you have a "clunk" now it means your splines collapsed further. I had one for about a year until I understood what was going on. The spline recession on mine was half way between your pictures and Jack's above (all my posts are listed in http://www.ferrarichat.com/forum/search.php?searchid=2968401. The specific one is http://www.ferrarichat.com/forum/showthread.php?t=207294&page=2) and I had a main shaft bearing problem.
    Every f-workshop I spoke to told me they were screwed and I would have to replace the shaft (not too expensive) but then the pair of drop gears as they were matched (VERY expensive) and throw on top a whole gearbox disassembly to replace the lower gear on the bevel shaft.
    What I did after realizing I only had to gain (and making a change the bearing again very improbable) as the parts would require changing, was to clean the shaft, gear and nut in brake cleaner. I bought a high strength (I remember working out that an adhesive strength of some 100Nm per square inch over the square area of the assembly point would mean I'd have more than 500 or so Nm of torque resistance, which we don't output - no nitro!!!) bearing adhesive - not loctite but another brand with a 24 hour cure time.
    I put a new bearing (you make it very difficult if not impossible to change it in the future) on, then a ring of gearbox silicone sealant on the base of the shaft where the gear rests on the bearing. I then covered the shaft and gear and assembled them. I also poured the adhesive in the little holes that would form on the worn edges of the splines, then twisted the shaft and gear so the worn edges were the mating line (that is where the torsion forces are applied in forward driving), then wiped off the overflow.
    I filled the holes formed on the reverse side now with adhesive, and shoved steel wire in the gaps (found some steel wire of the right diameter about .3mm i I remember properly) to absorb the forces that happen when you take your foot off the gas and the momentum of the car puts opposite forces on the shaft, pushing on it instead of being pulled by it.
    I let this cure overnight over a warm radiator. The day after I welded a ring around the ring nut end of the gear and shaft assembly permanently fixing the gear in place. I then drowned the threads of the ringnut and shaft with the same assembly and tightened it to 230 NM (maximum setting on my torque wrench). I then pinged the ring nut, but was unsure of the shallowness of the dimple. So I welded the base of the ring nut to the shaft.
    I don't do burnouts so to not tempt fate, but I have NEVER hear another clunk since - and I have been putting off buying a new shaft and gear set for over a year and some 10,000 miles of driving the car across Europe and on several tracks including SPA, Silverstone, Brooklands Park and Nurnburgring... Even if it all went to hell tomorrow I still think I got something out of nothing.
    I'll be swapping gearboxes in the next couple of weeks (the above is a rebuild I'm doing on my spare one) so I'll be able to tell you how the repair is holding up... But no clunks so far....
    Marco
  12. Ricambi America
    Sponsor Owner
    #12 Ricambi America, Mar 26, 2009
    My experience was quite different.
    My clutch shaft was initially repaired with Loctite too. It was done (at my request, against the smarter advice of my shop) to the exact specifications suggested by others by a factory trained 30+ year tech. It did not last 1500 miles, and my reluctance to fix the problem rather than patch it eventually cost me the complete gearbox. My driving style might be different than Marco's; my wear might have been worse than Marco's... I have no idea. But, for whatever reason in my particular situation, it did nothing except buy me a few months of driving and was not a long term fix.
  13. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    See, I think the key to the repair is to ensure the gear and shaft are fixed with the worn faces in direct contact. The natural tendency is to fix them on the unworn faces to ensure the right geometry. But that will also mean that the torsional forces in forward movement will act first on the loctite then on the faces (after it fails), leaving you where you started once the loctite loses adhesion. I used a specialized bonding agent that was both an adhesive and a high strength filler. Coupled with steel wire inserts to take up the slack on the rear of the rotational direction.
    If the faces are at contact then there is a solid continuance - adding the welding of the gear to the shaft adds more strength against the torsional force (Eventually I expect the weld will fail too - hence why I bought an additional gearbox)
    For my USD .02, I see the failure mode as follows:
    The gear splines and shaft will have some natural play i them. Every time there is a switch of power from where the car is pushing the engine along (taking your foot off the gas) to where the engine is pulling the car (going on the throttle) there is the same effect as one face beating on the other. Repeat this a huge number of times, you have metal fatigue and compacting deformation leading to the gap becoming bigger and the play widening. With the widening, you have more inertia on the face of the impact and so on, until the rate of the damage incurred at each impact grows and eventually leads to failure.
    The forces are distributed equally among the faces of the splines, and if the energy delivered on each impact per spline is greater than what the metal can absorb without fatiguing, you have the metal deforming. Increasing the number of splines (like the 355 shaft) increases the faces absorbing the impact and I would expect will reduce the energy absorbed per face to a level that is below the deforming threshold. I suspect increasing the number of splines was cheaper than having the gear be pressed hard onto the shaft (removing any play) and increasing the tensile strength of the metal (eg. using stronger but more expensive alloy or other metal).
    The ring nut is only there to keep the shaft from moving in and out against the bearing. The needle and ball bearing races keep the shaft in place radially, and the clutch flange keep it in place longitudinally against the forces of the clutch springs.
    But then again I could be very wrong... I applied deductive reasoning with very little metallurgical knowledge...
    M
  14. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    It's Loctite 271. Repeat after me, Loctite 271.
  15. fatbillybob
    Aug 10, 2002
    29,068
    socal
    The failure of the clutchshaft ringnut causing the ripping of the splines is the second most common failure in the 348 box. It was first reported to me on 3 348C cars that were raced. In my own case my ringnut was not even staked!!! When I reported that to FNA they just blew me off. I love those guys. Anyway the proper fix is a total diassasembly so that all gears are in matching pairs but you can just replace the gear and shaft and it will work fine. There theoretically could be some gear whine and early wear but guess what I did this on another box and it worked fine with no fanfare ant all. One is not an adequate sample size but it is a working datpoint. And I also don't see why you can just marry the gear to the shaft by welding either and I know I could weld it myself and it will not fail. Personally I would just heat treat it afterwords at home of maybe have a pro do that part. Skip all the locktite crap except on the stakering threads. And I was the person who first started using 271 not the factory recommended 242. My belief is that you don't want it to come off and when you want it to it will be many many miles from now and using a little heat to get it off is just fine. In my case the drop gear teeth had chipped off on some parts of the gear so a total teardown was needed. It would be very important to maybe magnaflux the clutchshaft gear to see if there are any cracks. Cracks = you can't weld the gear to shaft. You can see if there are cracks in the gearbox drop gear unless you take it out.
  16. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    I just glued and welded the thing so I could fix it in a weekend and am still driving it after 1 year and 10K miles. FBB - the typical racer - wants it perfect and it would be ;-)
  17. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, what was it again? oh yes... 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, now I'm getting it... was it 271? yes it was, look I know it 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, woohoo!!!!
    Hey Ernie, I meant to say I remembered the loctite number it was 243, shhhtit, I meant 271! (I'll get it right some day, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271, 271.....)
  18. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    LOL!
    Marco you goof.
  19. WillW
    WillW Karting
    May 23, 2005
    209
    Helsinki, Finland
    Ville
    Philip, luckily you are stronger than me as I just couple of weeks ago put my spare 348 gearbox to storage and had to call friend of mine to help as I couldn't move it with my muscles. :D
    Marco, great thread again! :)
  20. PAP 348
    Dec 10, 2005
    100,220
    Pap
    How about Loctite 277 guys?? :):)
  21. MaterMech
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    That's what I thought you guys meant when you said drop shaft. Well I guess my fix lasted about 2000 miles with a new locknut and liberal loctite. I cleaned the threads with brake-kleen but I guess loctite does nothing to fix the on off tortion between the worn shaft and gear. I believe the 355 shafts is the better replacement. With a new 355 cluctch shaft and it's bevel gear should I be concerned about it's match to the drop gear? I can tackle this in a weekend but I would like to save the gearbox out portion for when I pull the engine. I need to update the cam gears but time is not as available as it used to be. The Brotherhood rocks!!! I will try to get started this weekend and post some pics. I posted about a wheel bearing noise a few weeks back and it may just be this. Hopefully I can kill two birds with one stone. The car is no fun to drive when you are constantly thinking about its catastophic demise.
  22. fatbillybob
    Aug 10, 2002
    29,068
    socal
    #22 fatbillybob, Mar 26, 2009
    Hey...if you want to try an experiment I'll weld the gear to the shaft and maybe home hardening it for the huge cost of FREE! At worst you would have to take it out and do it again later. At best you would never have it fail again. I have home hardened tools made from mild steel used to Rand R ringnuts that has been passed around to many ferrari friends and my tools have never failed so far. Do you want to give it a try? It could be a brotherhood 348 permenant fix. I made a tool to remove the clutchshaft which uses 2 slide hammers and a rig to hold the shaft without damaging it. I can pull a clutchshaft in 10 minutes with it when there is clear access. I could send you up my tool as well but that would just delay the result another week.
    Oh...the day I get the shaft and gear I could weld it and harden it the same day and get it back to UPS the next day. It is really fast. Just send the gear mounted on shaft in the right direction. I forget if it is directional.
  23. Marco Bussadori
    Aug 6, 2007
    430
    London
    Marco Bussadori
    I did everything as I have low confidence in my welding skills (10K miles and still truckin' on is ok though). I thing FBB's experience and the fact it will all cost you less than buying the 355 parts sounds an excellent idea. FBB, they are directional, but just match the worn faces then you're fine. If you back the gear so the unworn faces touch then weld it in that position you're guaranteed good alignment.
    But we need pictures for this!!!
    M
  24. fatbillybob
    Aug 10, 2002
    29,068
    socal
    My welds will not break and it is free. I just need a test subject. I think this will work as a longterm repair. Really there is no reason to make that gear removable except to match gear pairs. Other than the spline part the shaft really can last in your car forever. And yes my recollection is the gear is directional but I don't have the gear in the gearbox to know which direction. So to get the gear welded on the right way someone has to orient it. Then I can square it up and weld it.
  25. MaterMech
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    #25 MaterMech, Apr 10, 2009
    Well I finally got around to working on the car. I would love a permanent fix and the only drawback to welding is that the bearing becomes non serviceable. It looks like the ring nut would have to be torqued for bearing preload and then welded to the shaft and gear. When I took this apart I was pleasantly surprised to see that it had not budged. The clutch shaft bearing had too much radial play for my liking so I bought a new one. The spline wear is actually not too bad so I think I'm going to reassemble it. It looks like the outer race spun on the clutch shaft and I'm guessing this happened when it initially failed. I think I'm going to use 271 to affix the race to the shaft but stop me if I am incorrect. There are two weep holes drilled in the shaft right where this race sits and I don't know if they are there to lube this race and it was designed to spin or if they are there to let oil out of the triple seal area. I did find a clutch spring on the intermediate pressure plate that was broken and hanging out at the bottom of the clutch housing. I think this is more likely the cause of the weird noises that I was hearing as it corresponded with the clutch engagement. FBB, do you have the socket for this ring nut? I was going to cut up a 3/4" drive socket to fit but it would be a lot easier if someone had it already. I was quoted $350 for it and that's just crazy.
