Another 348 transaxle question | FerrariChat
Discussion in 'Technical Q&A' started by spider348, Feb 8, 2004.
  1. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,275
    MA
    Similar to my last dilemma, ring nut rotation. Ring nut on the clutch shaft against the drive gear. Standard or reverse thread? Cannot get this nut to move. Shaft rotation indicates reverse thread. What is correct? Thanks for the help.
  2. Dr_ferrari
    Dr_ferrari Formula 3 Consultant Professional Ferrari Technician
    Nov 2, 2003
    1,073
    Pocono Sportscar
    Jim McGee
    As i recall that is reverse thread as well.
    best regards, Jim
  3. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,275
    MA
    Jim, correct, reverse thread. Ferrari factory assembler must have been really fired up when he assembled this shaft. Nut was sure tighter than 22daNm! Had to carefully cutoff after the teeth on my ring nut tool failed!
    Should have seen the look on my face when balls started flying everywhere! Was not aware the bearing had a split inner race.
