355 - Another 355 header question | FerrariChat
355 Another 355 header question
Discussion in '348/355' started by Fat-Thor, Sep 17, 2024.
  1. Fat-Thor
    Fat-Thor Rookie
    Aug 6, 2024
    9
    Sorry for yet another 355 header question.
    So I’ve finally put a deposit down on a 1997 Manual 355 Berlinetta. I don’t have my hands on it yet. It has the original headers which have passed recent testing. I may have the opportunity to replace them with second hand Tubi headers in good condition during the prep (for additional cost of course)
    I don’t have a money tree, but willing to invest if sensible.
    Do I change now or wait until the OEM headers become a problem?
    (there’s also a pair of used sports cats and Capristo exhaust available which I’m also in a dilemma about. But this is more frivolous)
  2. PaulK
    PaulK F1 Rookie
    4,781
    Michigan
    Paul
    Congratulations!
    I hope you enjoy it and that it gives you many years of motoring pleasure.
    You should replace them as soon as you can. The original headers will fail. Its not if, but when.
    The Capristo is a better sounding exhaust than the Tubi.
    ssnowball likes this.
  3. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    The original cats were part of the reason the headers would go bad - so switching to test pipes or sport cats could help prevent the issue in the first place. I believe my '95 with 56k miles has the original headers as there's no record of them being replaced in the last 20 years, but it was running test pipes and then sport cats for the majority of those.
    jjtjr and PaulK like this.
  4. fboutlaw
    fboutlaw Formula Junior
    Dec 3, 2014
    260
    Woodside, CA
    I'd personally wait until your first engine out to swap. It's so much easier to have the job done correctly.
    If they do fail, then that accelerates your first engine out when you clean up all the former owner's issues.
    sfcarguy and carnutdallas like this.
  5. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    I'd buy the manifolds, cats, and Capristo now. Drive a hard bargain to have them added to the deal at a low additional cost. And stash them away until your headers have trouble or you're doing an engine-out and it's super easy to change them.
    Yes, headers are a failure point on these cars. There are also huge numbers of 355's driving around on stock headers with no problems. My GTB has 39k miles and is still on the stock headers. There's no reason to change them unless, you know, they need to be changed. Pretty simple.
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    They fail. This is a header from my '95.
  7. huzilulu
    huzilulu Formula Junior
    Apr 20, 2011
    340
    Houston
    Huzi Husain
    I know you are considering Capristo but I have a Tubi from my F355 for sale - put about 4000miles on it since new … PM me if interested !
  8. sfcarguy
    sfcarguy Formula Junior
    525
    Earth
    ^^^This
    Not worth tearing the car apart until you actually need to. Do it once, do it right.
    308 GTB likes this.
  9. ssnowball
    ssnowball Formula Junior
    295
    Scot
    Smoke tested mine for piece of mind, purchased replacements the next year and had them installed with engine out service.
  10. Timmo
    Timmo Formula Junior
    Aug 26, 2017
    680
    Continental Europe
    Tubi headers are a must that should be considered right away when searching for an F355, for the reasons already mentioned.
    Then a twin chamber muffler, like the Capristo or Tubi Evolution should be added to replace the original single chamber muffler. Then free-er flowing cats or test pipes can possibly be installed. In the case of test pipes, they should not be used with a single chamber muffler.
    It all makes for a significant amount but well worth it in my opinion. I knew what I was digging into when I purchased my '96 and I replaced all of this right away (and replaced at the same time the poor stock radiators with full aluminium units).
  11. johnk...
    Jun 11, 2004
    11,217
    CT
    John Kreskovsky
    I installed my Tubi headers on my 95 engine in. Really not that big a deal. Pretty much everything that is in the way is in the way with the engine out. The biggest problem was getting to some of the nuts on the top side. Between the shape of the headers, the air injection tubes and the engine itself, there are a couple you have to use your imagine to get back on.
    https://www.ferrarichat.com/forum/threads/question-on-removing-installing-headers.634319/
