Do any of you experience this issue? You check out your garaged 360 in the morning (0600-1030ish) and it has that haze inside the lens that we just can’t get to, but you look again in the late afternoon or evening, and the haze is gone!! It’s clear as day in there. I’d hate to remove the headlights and there is no real issue there... just wondering if anyone else has notice their 360 doing this, and what can be done about it. I’m in Houston TX area, which is “ bursting in flames”hot most of the day... Sent from my iPhone using Tapatalk
I’m not sure... that’s my hope tho. My neighbor has a C07 Vet and said he had a similar problem, but it turned out that the lens gasket on his headlight had a leak, so when he washed the car (which he does weekly) water was getting into the headlight. I don’t wash mine 360 nearly as much, so I want to rule out any gasket issue or that water has gotten into the headlight. Thanks Sent from my iPhone using Tapatalk
