Another 612 battery question | FerrariChat
Discussion in '612/599' started by TrojanFan, May 20, 2025.
  1. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,158
    So. CA & NV
    Peter
    I know that the 612 takes a 34R AGM battery which is getting more and more difficult to find in stock. Batteries seemed to have doubled in price over the past few years and maybe I am just being cheap but I'm not looking to spend close to $500 (all in with sales tax) on the 34R Interstate Battery. Costco carries Interstate batteries but not the 34R.
    The 34R batteries generally have in the range of 800 -850 CCA. I live in California so not extreme cold for high powered starting and not extreme heat that often in my area. The H6 AGM Interstate battery is basically the same physical size, has the correct terminal position and has 760 CCA. Is the car going to notice the difference of those 40 CCA's? I keep her on my CTEK tender in the garage so we should always be at a full charge.
  2. fatbillybob
    Aug 10, 2002
    28,967
    socal
    It will work fine. You don’t need agm either.
  3. TrojanFan
    Nov 17, 2008
    5,158
    So. CA & NV
    Peter
    The last battery in the car was a Red Top. Probably had it 6+ years and never an issue. (Also had one in my 355 that lasted more than 6 years until I ran it down leaving the key on in the ignition for a week.) The tender showed the battery fully charged as I unhooked it to make a 2 mile trip to the gas station for a fill up. At the station, I went to start up and NOTHING. The dash flashed 2 times and then went blank. I knew it couldn't be the battery as it just had a full charge on my CTEK.
    Eventually I opened up the trunk and checked the battery. The negative post on the battery had come right off. No idea what would have caused that. No big bumps or pot holes on the trip. I'm thinking that it must have happened sometime earlier and was just sitting there still making contact. Never seen a terminal post sheer off.
  4. fatbillybob
    Aug 10, 2002
    28,967
    socal
    I’m happy if I get 5 years out of a battery. I only use Costco interstate batteries. I match by first terminal position, then crank amps, then physical size in that order. It’s horseshoes just be close. Costco does not have the 2 batteries for my ram diesel so I just eyeball it and on battery set 2. I’m in snow country a lot of the year.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,895
    Central NJ
    Dominick
    I'm really liking the Duracell AGM at Sam's or a battery Plus 34r
    Made by Penn
  6. TrojanFan
    Nov 17, 2008
    5,158
    So. CA & NV
    Peter
    That's what brings me to an H6. The 612 has a tight battery compartment. The H6 has the right terminals and battery size. The CCA was slightly lower at 760.
  7. fatbillybob
    Aug 10, 2002
    28,967
    socal
    Yeah that's close enough in CCA's. You will be fine.
  8. gsholz
    gsholz Formula Junior
    347
    Oregon
    Jerry
    H6 works just fine. You may get old stock when buying a 34R. I bought a Odyssey 34R online from Summit Racing that turned out to be 2 years old and died within 8 months while being on the Ferrari maintainer. Still pissed.
