Another belt thread? Yep | FerrariChat
Discussion in '308/328' started by robbie, Jul 1, 2008.
  1. robbie
    robbie F1 Rookie
    Aug 26, 2005
    3,015
    Los Gatos, CA
    Robert
    In two weeks my 88 328 is going in for its second Major .. has 28,000 miles .. first one done in 2001 at 23,045 miles. I know .. only about 5,000 miles on the belts but 7 years. Guess FChat has made me very paranoid. My question is, are all the components .. belts, tensioners, bearings, etc. of the same quality or should I be specifying specific brands, names for these? My mechanic is outstanding and is very familiar with 328's but in the collective wisdom out in FChat Land maybe there are a few tidbits of data that can be applied to my project. Thanks in advance.
  2. mwr4440
    58,067
    Bavaria, The 'Other' Germany
    Mark W.R.
    Robbie,
    Lots of threads/posts about fake bearings within the past few months. Check them out. Only buy from known F-Car suppliers. Skip the "deals." Not worth it IMO.
    Second; belts. Call the company and check the date of manufacture. People here have gotten belts (NOS) as in NEW but VERY OLD stock.
    I know I am a bit paranoid, but IF it makes you feel better ............... It is one of the newest scams going.
    MWR
  3. GeoMetry
    GeoMetry Formula Junior
    Apr 14, 2008
    471
    Virginia
    Richard
    The major is of course much more than belts and tensioner bearings. Other than changing the fluids belts are actually one of the easier things they do as part of the major service. The valve adjustment the valve timing. Cleaning the fuel injectors. Adjusting the idle and CO mixture. re-torquing the heads replacing various seals, gaskets, belts and hoses. Quite often they will replace the water pump also. At the Ferrari dealer I took it to they also detail the car inside and out and they picked up the car and in a covered flatbed for no additional charge. Keep in mind that if you supply the parts the dealer will not warranty them. If something goes wrong the parts supplier and the dealer will point at each other. But it sounds like you are not going to a authorized Ferrari dealer anyway.
    My car is in for its major as I write this. They are also replacing the bearings on the cam belt drive pulleys. I stopped by to see how it was coming along and I got a look at the old ones and they were a disaster waiting to happen. Added another $1500 to the job. see this thread. So the major cost me $6000 and the bearings added $1500.
  4. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    17,085
    Wellington, FL
    Duane
    I gotta +1 this post. There is a lot more that goes into a major then fluids and belts. I think the main reason for catastrophic failure is when a bearing/pulley fails so the belt skips and grenades an engine. My mechanic, an independent (Tim Stanford) only uses stock Ferrari parts. His reasoning--if there is a problem, it's Ferrari's problem. But I would trust Ricambi/Hill Engineering parts on my car, they are stand-up guys.
  5. mwr4440
    58,067
    Mark W.R.
    Holy crap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I wish I could afford $1500 for a pair of $45 bearings (each).
    Turn your own wrench brother. Put those hard earned $$$$$$$$$$$$$$$$$ against something more usefull.
    Respectfully,
  6. Dr Tommy Cosgrove
    36,597
    Birmingham, AL
    Tommy
    Well, It's pretty clear how they were able to afford to pick up the car for "free".
  7. GeoMetry
    Apr 14, 2008
    471
    Virginia
    Richard
    I purposely didn't use the word "Free" because I realize I am paying for it.
    I do quite a bit of my own work (I replaced my own timing belts, coolant lines, fuel lines, water pump and fuse blocks) but I can afford it and I felt that a proper major by a qualified trained Ferrari mechanic was worth the price. I will also tell you that the mechanic spent an entire day getting those bearings out and I don't regret avoiding that frustration.
    On a happy note he informed me that my car aced the leak down and compression tests!
  8. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    #8 Verell, Jul 4, 2008
    6-8 hours more or less is about the right amount of time to change the front timing drive bearings if you're already doing a major & have the belt covers off.
    Let's see, ($1500 - ($100 x 2 bearings))/8 = $162.50/hour!!! Yes, the bearings are $96 ea on Ricambi's site!
    Surely he did something else as well...
    BTW, that picture you referenced looks like a timing drive bearing AFTER the separators were punched/drilled out on each side to hook up a Sykes bearing puller tool.
  9. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    If it is the lower cam drive bearings Part #121274 they are $267.84 from Ricambi. So 2 bearings alone would be $535.60 Remaining labor of 8 hours = approx $120 per hour.
    Those bearings are very often overlooked on a major. If one of those fails - you are looking at a helluva lot more than the cost of replacement even at $1500.....
    As these cars approach 20+ years old at best - you better put these on your list of "to-do"s on your next major as with all the rubber fuel/cooling hoses.... My 2 cents.
    Chris
  10. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    OOPS! MY BAD,
    Chris has the right bearing p/n & price for your '85 328. I looked up the outer timing drive bearing for the earlier models, it's an industry std. The later QVs & all 328s use a larger OD F* unique bearing that's gotten really pricey!
    The outer timing drive bearings on all but the earliest carb'd 308s are sealed bearings, the lube slowly deteriorates with age & heat. IMHO, they should be changed every 10-12 years for normal use cars, every 5 years for tracked cars, especially when driven in 90+ F weather.
  11. mwr4440
    58,067
    Mark W.R.
    OOPS! I thought we were talking about tensioner bearings ---- My Bad!!!! Sorry Robbie.
