355 - Another Capristo question... | FerrariChat
355 Another Capristo question...
Discussion in '348/355' started by radback, Oct 1, 2023.
  1. radback
    radback Formula Junior
    751
    France
    Hi,
    why some models have perfored caps on the side, and others have plain caps?
    Does it have something to do with sound level?
    Thanks.
  2. radback
    751
    France
    No one knows the answer of this question? o_O
  3. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    462
    London
    Steve C
    Capristo will know. Have you tried to contact them?
  4. radback
    751
    France
    I just did.
    I'll post here if I get any return.
  5. radback
    751
    France
    No return; neither from Capristo Germany nor Capristo US.
    I'm surprised nobody knows about this. o_O
  6. 250boano
    250boano Formula Junior
    Apr 27, 2022
    450
    Europe
    DD
    Level 3 has perforated caps
    Levels 1 + 2 have solid caps
    radback likes this.
  7. radback
    751
    France
    Thanks.
    I also found this post with some infos:
    https://www.ferrarichat.com/forum/posts/137895785/
    Not sure if they're accurate though.
    The german link has more valuable info from Capristo.
    For what I understand, there are Capristo with 2 plain caps (stage1), and some with 2 perforated caps (both level 2 and 3).
    You have to see through the holes if there is silencer material in it to know if i's a stage 2 or 3.
  8. 250boano
    Apr 27, 2022
    450
    Europe
    DD
    I spoke to Ralf last night who is the Head of Technical at Capristo and he gave me the info I posted.
    That post from Antonio is pretty old so I'd go with Ralf's current info over what Antonio said all those years ago!
  9. radback
    751
    France
    It depends of why you need this info. Might be true for current production.
    In my case, it is for a second hand exhaust, so the old post from Antonio might be more corresponding to an old exhaust :)
  10. cactussed
    cactussed Formula Junior
    Mar 12, 2008
    286
    FWIW, I have one of the very early Capristo Level 1, which has the perforated caps. I believe it's equivalent to a current level 2, whereas the current level 1 has a larger upper chamber and the end caps are solid (I think).
    I'd imagine it's a noise thing, although how / why I don't know as you wouldn't have exhaust gas exiting there. Maybe they don't have any wadding inside the ones with perforated caps?
    Either way, it makes a belting noise.
  11. radback
    751
    France
    It is alway hard to figure which model or sound levels with Capristo. So many different informations.
    Adding fluctuations in production doesn't help.
    What do you mean by "belting noise"?
  12. 250boano
    Apr 27, 2022
    450
    Europe
    DD
    Level 2.
    1 there is too much difference between loud and quiet, 2 there isn't enough difference between loud and quiet.
  13. radback
    751
    France
    Yes, I'm afraid of the ON/OFF effect that a level 1 could have.
    I'm sure the level one Capristo is quieter than my Larini at iddle, but I'm worried it could be louder when valve is open.
    Maybe a Tubi Evo would be better for me...
  14. Johnnieblack115
    Johnnieblack115 Karting
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    I have a Tubi I’d like to get rid of for a capristo…
  15. radback
    751
    France
    You've got aTubi EVO, or the old type Tubi?
  16. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    The older model, without the dedicated pipes for primary/ bypass
  17. radback
    751
    France
    I understand.
    Why not getting the Evo instead of a Capristo?
    It is cheaper and I think close in quality.
    I had set my mind to buy a new Evo, but someone offered me a second hand Capristo (stage1 I guess) at same price.
    I'm planning to buy it, and if I don't like it, I'm sure I could resell it fast.
  18. Johnnieblack115
    Nov 18, 2022
    220
    Massachusetts
    Jonathan Walker
    I don’t have enough data on the evo, but my guess is that it still doesn’t produce that same as shriek that a capristo is notorious for.
    I really want the kreisseig ultimate but can’t justify the price
