Another Check Engine Light Issue | FerrariChat
Discussion in '348/355' started by 2MS, Nov 8, 2016.
  1. 2MS
    2MS Formula Junior
    Oct 5, 2004
    342
    Bay Area, CA
    Mark
    Driving the F355 around in the past month or so and got CEL 5-8 engine light. No slow down light came on or performance loss but was able to pull in the garage safely.
    Attempted to pull the codes but no indicator light came on. Decided to reset the ECU and drove it around some more but the light re-appeared and then disappeared but as I soon as I was almost home the light came on again.
    Upon my search I found the following things I should do/check.
    - replace the O2 sensor
    - check MAF connector pins and clean them accordingly
    Am I missing anything else?
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,040
    Indio Ca/ Alberta
    Grant
    Whenever mine comes on its allways been a o2 snsor but yours is a 95 so I think it is less likely. You need to pull codes and then you will see.
    The cat might be worn out or going out.
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    It seems that with a 2.7 and intermittent CEL with no code leads to O2 sensor. But myself and JohnK have experienced this and replacing the O2 sensor resolved the issue. I'd also suggest you do both as they fade over time and are very cheap. Amazon has the best prices.
  4. WATSON
    23,863
    WI
    #4 WATSON, Nov 9, 2016
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    355 :)
  6. WATSON
    23,863
    WI
    I see. Then yes, the Bosch O2 sensor will work :)
  7. WATSON
    23,863
    WI
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I think they are basically the same on the outside (same threads, etc.) - it's just the guts that are different.
  9. 2MS
    2MS Formula Junior
    Oct 5, 2004
    342
    Bay Area, CA
    Mark
    Thanks guys for your input and have purchased the O2 sensor and will give it a try.
    Also, what are you thoughts about the gold connector kit? I was thinking of replacing my stock ones on the next engine out.
  10. 2MS
    2MS Formula Junior
    Oct 5, 2004
    342
    Bay Area, CA
    Mark
    The O2 sensor is both found on the cat and by the engine bay? Which one do I replace?
  11. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Many threads and debates on the forum regarding this. I'll say that the electrical connector industry (years of data, testing and engineering) state to no mix dissimilar metals for connectors. That said, I don't support the product for those reasons.
    I suggest you replace both but the 5-8 is on the left side (LHD driver's side)
  12. WATSON
    23,863
    WI
    Well, The Gold Connector Kit (GCK) is a bit like a religion. Some people swear by it.
    FWIW, I took most of the gold connectors out of my car last winter. It is running much better now.
    Personally, I am of the opinion the material matters little. The actual connection engagement is the key. Any new connector will improve connection...gold or otherwise.
    This is a fun thread about it: http://www.ferrarichat.com/forum/technical-q/326310-stooge-tin-pin-connector-kit.html
  13. 2MS
    2MS Formula Junior
    Oct 5, 2004
    342
    Bay Area, CA
    Mark
    Thank you both Dave and WATSON for your inputs.
  14. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,040
    Indio Ca/ Alberta
    Grant
    I am one who swears by it, the gold connector kit, but if done wrong it will cause more grief than left alone.
    What Watson said has a lot of merrit though, new connectors on a 20 year old car are likely better especially if the grip is better and will,likely out last the ownership in many cases.
  15. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,272
    CT
    John Kreskovsky
    GCK = fools gold. Sorry Grant.
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,040
    Indio Ca/ Alberta
    Grant
    I did it quite a while ago had I know about other choices and if i had the time and patience to source likely I would have done different.
    My feeling is time is money and at the time I had more money than time.
    No offence taken. All good John.
    Ps the other good thing was when I had an issue I had paid for some over the phone advice which also helped.
    Did not have you or Dave Rocks available at time if I recall correctly. Like all things in the last 8 years public knowledge on these cars has come a long ways.
  17. 355rockit
    355rockit Formula Junior
    Dec 1, 2010
    893
    San Marcos, CA
    Vas
    Previous owner here.... the 5-8 MAF connector has not been clamping well when I owned it and wiggling it causes engine sound changes. I had noticed a pin was offset in the MAF (after replacing the O2 sensor and throwing money at it). Moving pin back into position, it had no new 5-8 lights for a long time. The suggestion is not gold vs tin, but a more solid connection to the MAF connector.
  18. 2MS
    2MS Formula Junior
    Oct 5, 2004
    342
    Bay Area, CA
    Mark
    Thanks Vas. Would you recommend looking at the MAF pins positioning and possibly cleaning them as oppose to replacing the o2 sensor?
