Another Diff Bites The Dust… | Page 3 | FerrariChat
Discussion in 'Boxers/TR/M' started by RQtetto, Jan 18, 2014.
  1. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,296
    Mel
    Good Luck Brad.
    As ever: please have photos taken (for us)of the many steps in the process of replacing the upgraded diff.
    Your diffs will all follow .... it's not a matter of IF but it's a matter of WHEN .... they will all go.
    Be in time ... avoid massive costs.
  2. Bradwilliams
    Bradwilliams F1 Veteran
    How many miles were on your car when yours went Mel?
  3. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
    If anyone is looking for a stock OEM diff I have one....$1100 shipped
    Diff erent Me
  4. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,663
    romano schwabel
    broken or ok :)
  5. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    In great original condition... came out of my 87 at 45k. Replaced it with a billit diff from Newman..
    Preventive Me
  6. turbo-joe
    Apr 6, 2008
    9,663
    romano schwabel
    for using this diff as an ashtray too expensive for me
    then I better use my broken diff - even I´m non smoker :)
  7. JB833
    JB833 Karting
    Jan 3, 2015
    107
    London
    Hi, I have just bought a Testarossa and asked the garage about diffs. They said they have only ever seen three go and it is not a foregone conclusion. I was prepared to change the diff but they have said don't bother. I am unsure what to do. Why do you say they will all go? Just curious..
  8. turbo-joe
    Apr 6, 2008
    9,663
    romano schwabel
    then go again to the garage and they may give you a warranty that the diff will not break. otherwise they may pay all the additional material and labor.
    it is only a question of "when will it break", not "if"
  9. Bradwilliams
    We should start a poll on the percentage of diffs breaking in these things LOL.
    From what I've heard it sounds like a total crap shoot. Many including myself think that it depends on how the car has been driven. Many were clutch dumped their lives. Hard to connect the dots though if you ask me. Sounds like Vegas.
  10. JB833
    JB833 Karting
    Jan 3, 2015
    107
    London
    I'm going to asume that more diffs haven't broken than have unless someone can tell me otherwise.
  11. turbo-joe
    Apr 6, 2008
    9,663
    romano schwabel
    may be you are right - but may be not
    but when the diff breaks then there is a lot of more to fix and that will get very expensive
    same as with the fusebox, but there the costs are much lower
    preventing and to be on the safe side I suggest - but everything to his own
    as newman also said: the diff may be broken without you feel it, but when you dismantle then you see it. when you are so far you are lucky - but mostly nobody sees ist and some day it will destroy much more things
  12. dwhite
    dwhite F1 Rookie
    Same with timing belts, but they get changed way more than necessary.
    I drive my cars, so when I bought my boxer there were 2 things I wanted to do immediately; replace all the suspension bushings and do the diff as a peace-of-mind preventative mait., the major was done the prior year by Ferrari. When I did the Newmann diff I also did a bunch of things which don't get done on a typical major and corrected those which they did poorly. I do drive it alot (7-8K in the last 3 years) so it was good money spent and 2 1/2 months of my time.
    It's all personal choice and if I were a waxer polisher type, I probably would not have bothered doing suspension or diff., then again I would never have bought a boxer.
  13. turbo-joe
    Apr 6, 2008
    9,663
    romano schwabel
    I never heard that the diff in a boxer is broken
    but the example with the timing belts is perfect ! ! ! :)
  14. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Great post! I so wish it doesnt happen to me. I try to do everything you said. Knock on wood!
  15. ago car nut
    ago car nut F1 Veteran
    5,553
    Madison Ohio
    David A.
    IMHO, I think it happens because of improper stress relieving after welding. I do not believe it will happen to everyone.
  16. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
    Very possible. I also think it has something to do with the hand grinding/cleanup after weld......at least it appears that way. Very inconsistent and uncontrolled process.
    But, if the same diff was used on the Boxer and they rarely ever break, then it must also have something to do with the increased horsepower of the TR.
    Here's a Cause and Effect Analysis we started a while ago
    http://www.ferrarichat.com/forum/144747814-post179.html
  17. Melvok
    Jul 25, 2008
    14,296
    Mel
    This diff was made for handling 300 HPs Sam ... in the 365 and 512bbs
    Not 400 HPs or even 426 (512TR) ...
    That's why ...
  18. ago car nut
    5,553
    Madison Ohio
    David A.
    Installing a Newman diff in my TR even if they all don't break.
  19. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,555
    Canada
    Newman
    The welds got lighter over time. Look at a 365 boxer one and it has such a fat bead they have to machine them down to clear the left side support. The BB512 got a lighter weld that had the high spots machined off, Testarossa ones have a smaller weld that needs no machining step! The down-side......kaboom!
  20. Newman
    Dec 26, 2001
    14,555
    Canada
    Newman
    Thank you again :)
  21. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    That's what I did and had peace of mind everytime I drove the car. I still have my unbroken OEM and it does a great job on the shelf.
  22. stardoc
    stardoc Formula Junior
    May 5, 2005
    669
    The big oven
    K RA
    So, to recap. How much are you guys paying to install a Newman diff?
  23. Bradwilliams
    I'll let you know the labor cost when mine is wrapped up.
  24. Melvok
    Jul 25, 2008
    14,296
    Mel
    That is a good idea ! :D
  25. turbo-joe
    Apr 6, 2008
    9,663
    romano schwabel
    it depends if you let it do just when the engine is out for a major service or only change the diff with the engine in the car.
    when the engine is out I need between 3 and 6 hours, it depends how often I have to remove the diff for shimming and adjusting the bearings and also check the play between crown and pinion
