Another garage floor thread | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by BoulderFCar, Nov 18, 2007.
  1. BoulderFCar
    BoulderFCar F1 World Champ
    12,191
    Asheville, NC/Ft Lauderdale
    Tom
    I want to finish my garage floor. I’ve used epoxies before but was never satisfied. They are very slick when wet unless you put grit in it which I don’t like. Also, I’ve had them professionally done by companies that do aviation hangers with the best materials and they still peeled up. Tile will not work for me as I pull jacks across it and I also would have drainage issues as I wash cars in the garage.
    I’m looking for a stain with a semi-gloss finish that is resistant to gouging but still has some color to it. I’ve also heard of processes that grind/polish color into the floor. I’ve seen it in commercial warehouses but can’t find anybody who does it.
    The garage has an unfinished concrete floor that is clean and 5 years old. It is always heated and 2800sq’. I do wash on it and have a heavy truck I park on it as well.
    Any ideas or experience with a stain type factory floor finish? Thanks.
  2. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    You are kind of limited once existing concrete has hardend, unless you go with epoxies/paints/mutli stage/etc...which it sounds like you don't want.
    For me, the floor tells as much a story to the garage as any part of it. The oil spills, the place where the jack fell and made a huge gouge are all part of the patina of a garage.
    Not everyone likes that and I can understad/respect it.
    As per your post, tile is out....
    Perhaps polymer mats, snap tiles or some other high tech floor covering....
    Good luck.
  3. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    The snap together tiles are actually good for places where you wash the car since they have a dimpled support pattern that allows the water to run off the slab under the tiles. The only concern is about the floor jacks, but I just put a block of thin plywood under it when I use it. Plus they look great! I'm using a stain on a house in Scottsdale, I'll try to find out the name of it.
    BT
  4. cobmw
    cobmw Formula Junior
    442
    Rocky Mountain area
    Polishing is an option. I was quoted $5.50 per sq ft (compared to $3.50 for epoxy). They go over the floor with a very large polishing machine (100 amps) using progressively finer abrasives. Takes seven cycles. Finished floor has an extremely hard surface impervious to fluids. The surface is supposedly not as slippery as epoxy. Going to have the work done in Dec/Jan.
  5. BoulderFCar
    12,191
    Tom
    Thanks Bill. Let us know how it works out. The more I read about it I think stain is the way to go for what I want to do. I just need to find someone that has used it as there can be a chasm between what a product says it can do and what it does. I also like the patina of the stains.
  6. GrndLkNatv
    GrndLkNatv Formula Junior
    Sep 13, 2006
    878
    Grand Lake, Colorado
    Mark Stephens
  7. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    That's the main reason we chose the stain over an epoxy colorant. We will be putting an epoxy clear coat over the top anyway. This is to enhance the sale value and not what I would want in a garage that I am working in. We plan on using an acid etching stain in a similar color to the 'cola stain' on the link:
    http://www.concretenetwork.com/stained-concrete/colorchart.html
    you might also want to try this out:
    http://www.concretesolutions.com/concrete_dye.html
    BT
  8. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,505
    Tuscaloosa, AL
    Drew Altemara
    As COBMW mentioned above. Polishing is a very good option. It is being used in a lot of convience stores; and slippage is an issue there. We have one close to us that had the floor cut (maybe 1/8" deep) in large diamond sections then polished and it looks very good.
    I've painted/epoxied several times and it always comes up and I am pretty hard on my floor. Next time I am going to have the concrete polishing done with maybe a design cut into it.
