Another QV engine nearing completion | FerrariChat
Discussion in '308/328' started by fastradio, Jul 25, 2012.
  1. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    #1 fastradio, Jul 25, 2012
    Shortly another comprehensive QV engine overhaul will be leaving my shop and heading back into the wild. It's been a long road, with many twists and turns. However, not only is she pretty due to significant effort made by the owner, she was done correctly with only the best of the best materials and shop procedures used.
  2. TacElf
    TacElf Formula 3
    Aug 15, 2010
    1,719
    Seattle area
    Jeff
    Simply gorgeous, but it's the "done right" part that's most important. Let us know when you turn her over for the first time -- that's gotta be a thrill.
  3. 308gtsqv
    308gtsqv Formula Junior
    Feb 12, 2008
    610
    Mass/Cape Cod
    One day..
  4. Icandrive
    Icandrive Rookie
    Apr 29, 2012
    22
    Ma
    Harry
    Cant find it but is there a thread on the work?
  5. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,857
    Atlanta
    John!
    Lookin sharp
  6. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    are the cam covers polished or painted?
    Looks sharp.
  7. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Thanks. As I recall, they are powder-coated.
  8. schumacherf2006
    schumacherf2006 F1 Veteran
    9,047
    Chris
    Post a video of the first time turn over
  9. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    That's one pretty engine.
  10. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    WOW
    gorgeous
  11. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    #11 fastradio, Jul 25, 2012
  12. Dr Tommy Cosgrove
    36,450
    Birmingham, AL
    Tommy
    Can you list some of the "best of the best" part options that were used? These are things I need to keep in mind
  13. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Absolutely-
    Wiseco pistons
    ARP rod bolts
    Vandervell main and rod bearings
    Teflon valve stem seals (versus the nylon OEM ones)
    OE engine gasket kit, not that "black gasket" junk
    I think this gives you some idea...
  14. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    Art, David.....really beautiful work.
  15. Dr Tommy Cosgrove
    36,450
    Birmingham, AL
    Tommy
    Any upgrades such a compression, etc? Things like that?
  16. ztarum
    ztarum Formula 3
    Mar 30, 2008
    1,302
    South Jersey, USA
    Very nice! Are the yellow paint dabs correct for the injector ferrule/nuts?
    I know lots of the bolts and clamps were dabbed, but I hadn't seen that before. Not being not picky, just curious in case I ever give my engine the full detail.
  17. George Vosburgh
    George Vosburgh F1 Rookie
    Beautiful work, congratulations!
  18. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    No, just a temporary assembly reference for me that will be removed just prior to starting....
  19. italianjoe
    italianjoe Formula Junior
    Jun 30, 2010
    295
    dearborn heights mi
    joe
    Great job David that is truly the work of master ............ as a mechanic of 28 years i am truly impressed
  20. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    I noticed the distributors didn't have the protective black rubber boots. Any reason?
  21. Jdubbya
    Jdubbya The $10 Trillion Man
    43,240
    PNW
    Beautiful job!!
  22. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Look a bit closer, they're new and installed...
  23. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    -On the QV, compression can easily be raised, as long as piston to valve clearance is checked. Both of these engines run a Wiseco custom forged piston with 9.74:1 compression. Modern piston rings used. Although I could have gone higher, long term reliability coupled with fuel concerns dictated a more conservative approach.
    -Valves and guides new. Made to order valve guides that are undersized on the i.d. This enables us to get the precise valve stem to guide clearance I want. As new, Ferrari was very lax in this department.
    -Crankshaft oil galley plugs removed. All internal passages cleaned, cleaned and cleaned...
    -All components Magnafluxed
    -All components re-balanced
    -All piston rings fitted by hand and ground to size. Immensely time consuming, but yields consistently low leakdwon.
    -Block checked/line honed as needed
    -Heads checked/line honed as needed
    -Intake ports matched, as needed
    -TDC verified
    -Cam timing set with a degree wheel
    There is really nothing special here other than just your old school, leave no stone untouched, engine rebuilding techniques.
  24. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    #24 fastradio, Jul 26, 2012
    Thanks Joe. Those are very kind words. These are very special cars and warrant the best care, in my opinion.
    The engines are fairly straightforward to get right. As they say though, the devil is in the details...and that takes a considerable amount of time to get right. In the first set of engine photos, the owner chose to powder coat many of the engine components. It looks pretty, but the finishes are not OE. However, the second set of engine photos, the goal was to stay as close to original as possible with everything. All of the aluminum was cleaned and prepped in a multitude of ways to get back to the factory look and feel. Many of the hardware bits were re-plated...The list is extensive regarding all of the little extra steps taken to achieve precisely what the owner wanted.
    On both cars, the owners were actively involved in prepping the engine bays and surrounding chassis area, prior to the actual engine installation. Credit were credit is due...
  25. brettski
    brettski Formula 3
    Feb 29, 2004
    1,754
    north of toronto
    brett swaykoski
