Another simple physics question | Page 2 | FerrariChat
Discussion in 'Other Off Topic Forum' started by 2000YELLOW360, Dec 15, 2005.
Relative to the person throwing it, does it
  1. A. Accelerate all the time
  2. B. Accelerate, then decelerate
  3. C. Decelerate, then accelerate
  4. D. Maintain a constant velocity V
  5. E. Always have a velocity of zero.
Multiple votes are allowed.
Results are only viewable after voting.
  1. Jdubbya
    Jdubbya The $10 Trillion Man
    43,692
    Hell's waiting room
    I voted but in reality you don't have a correct answer to vote for. It will technically accelerate (until it leaves your hand), then decelerate (as it rises), then accelerate (as it falls), then stop (as it lands).
    Assuming only two choices, I would have to stick with my original answer (this is assuming that the start is after it has left my hand).
  2. ghost
    ghost F1 World Champ
    Dec 10, 2003
    10,046
    Singapore
    Thanks for posting my PM to you Hessian - :D
  3. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    We are only dealing with what happens to the ball/object after it leaves the hand. Thanks.
  4. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    In case people did not see it on the first page:
    Deceleration means negative acceleration.
    Acceleration means positive acceleration (the vector points the other way).
  5. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,480
    SFPD
    Dirty Harry
    If air resistance is ignored, the ball will move with constant acceleration.
  6. vvvmd
    vvvmd F1 Rookie
    4,703
    close to the Hub
    Victor Villarreal
    misread the choices should have voted for C
  7. shiznut123
    shiznut123 Karting
    Nov 15, 2003
    93
    acceleration is a constant ~-9.81m/s^2 OR ~9.81m/s^2 depending on how u set up your positive and negative coordinates.
    So i chose A, since the mass is in constant acceleration.
  8. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    the doctor recommends an enema!
  9. exotics4fun
    exotics4fun Karting
    May 13, 2005
    84
    The definitions you supply are a little bit akward re: negative and positive. Any change in velocity is typically considered an acceleration in physics. If that's the case then I'm pretty certain option A is correct: the ball is in a state of constantly changing velocity relative to the thrower, so it's actinig under constant acceleration.
  10. jsa330
    jsa330 F1 World Champ
    10,059
    75225
    Scott
    I guessed A, the ball is either in a state of upward acceleration, which may slow but is acceleration nonetheless, or downward motion, in which velocity is constant if gravity is the only force influencing it. The transition period between the the two states has be nil...the ball never stops completely.
  11. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    I did try to clarify it. Yes, the wording could have been better. You are of course correct.
  12. ashsimmonds
    ashsimmonds F1 World Champ
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    exactly. another simple one. :)
  13. afwrench
    afwrench Formula Junior
    Nov 24, 2004
    593
    NY
    It all depends on how fast the conveyor belt is going!
  14. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    OK answer time. The only force acting on the ball is gravitational acceleration. It is always positive, downwards. So, relative to the boy, the ball is always accelerating. The acceleration is always positive.
    I could have worded it better. Those who said it is decelerating and then accelerating are on the right track. But after I clarified twice that acceleration means positive acceleration and deceleration means negative acceleration, the only right answer was A.
    The key here was that it was accelerating positively with respect to the ground while it was going up. Since it's velocity was negative, the positive acceleration downward caused the negative velocity downward (positive upward) to decrease. Once it decreased to zero, the ball reached its peak and started to accelerate due to the only force acting on it. This was gravity pulling it downward. So it accelerated downward (positively towards the earth). So its speed kept increasing and it went down faster and faster till it hit the earth.
    The acceleration was positive at all times with respect to the boy, who is on the earth.
  15. micah
    micah Karting
    Aug 12, 2005
    155
    Buffalo, NY
    Micah Weber
    if only people realized it was a public poll....
  16. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    Someone mentioned coriolis forces in this thread.
    Here is a great, great explanation. I wish someone had explained it to me this well in school. I had to try and understand it from a physics textbook, which wasn't very good.
    http://ww2010.atmos.uiuc.edu/(Gh)/guides/mtr/fw/crls.rxml
  17. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    Art: Can you explain why the correct answer is not B? When the ball hits the ground, it decellerates.
  18. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    First of all, you choose to misinterpret the question and look at boundary cases. If you were to interpret it the way you have, there would be several stages:
    acceleration in the hands of the thrower
    deceleration going up
    acceleration coming down
    deceleration on impact
    and numerous smaller cycles as it bounced.
    Clearly you have to be delusional to interpret the question like this.
    Secondly, if we are talking about acceleration per se, nope, it does not decelerate when it hits the earth. It's speed goes to zero instantly. There is never a period where it "slows down. You can also say, tt keeps accelerating but the acceleration is countered by the hard surface of the earth not giving way so all it can do is press down with its weight. This is not enough to bore a hole through the surface and keep on accelerating due to the gravitational acceleration.
    The ball is always accelerating due to the force of gravity acting on it. Even when it is at rest. Just like you and every other object on this earth. We are of course neglecting all the other forces acting on objects on each, wind, magnetic fields, Ferrari seats pushing you forward very hard, and so on. On earth, gravitational acceleration is ALWAYS constant and positive in the down direction.
    Unlike your question about the wiring, this is not a trick question. It just requires an understanding of physics principles.
    I also clarified it twice.
    Decelaration is negative acceleration.
    Acceleration is positive acceleration.
  19. ashsimmonds
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    not in relation to the boy though, which is the question you posited. it's attempting to accelerate, meaning it has an accelerative force being applied, but it's not effective due to other factors.
    perhaps my perception is misaligned but to me accelerating means moving at a measurably higher velocity than the moment just before it (relative to whatever).
  20. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    Ash, see my clarifications above. You are of course correct.
