another timing question | FerrariChat
Discussion in '308/328' started by decardona, Feb 20, 2010.
  1. decardona
    decardona Formula 3
    Apr 23, 2005
    1,019
    PA
    Dennis Cardona
    Thought I reset the timing on the 308, but on further review, didn't. When I put a timing light to it, thought I was seeing the mark, but from the opening on top, it was a bolt. Only realized this when it happened to stop where I could see it. I didn't see anything thru the slit in the back. Is the timing so far off that I am missing the mark, or am I missing something in my method.
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    Is your timing lht hook up to cyl. #1?
  3. Steve Magnusson
    BANNED Lifetime Rossa
    26,822
    In addition to Mike's point, have you first "manually" found the timing marks (and you have two sets of marks -- one set for cyl #1 and another set for cyl #5)? Often, they are so subtle/corroded/unclear, that you might need to add an auxillary paint mark on the clutch housing (inline with the true "mark") to see them more easily when running.
  4. decardona
    decardona Formula 3
    Apr 23, 2005
    1,019
    PA
    Dennis Cardona
    This was the problem. The real marks were so faint, they were very hard to locate. Once I had the correct marks, I remarked them and was done in 10 minutes. Thanks for the input.
