Another Water Pump? | FerrariChat
Another Water Pump?
Discussion in 'Technical Q&A' started by JTranfield, Aug 20, 2005.
  1. JTranfield
    JTranfield Formula Junior
    Dec 29, 2003
    665
    NYC, London
    J Tranfield
    Just had a great drive in the 308 and came home to find coolant dripping really badly from the waterpump housing. Left the car parked and its probably lost half its coolant in an hour. Any way must be the pump as its leaking from the lower gasket area. Assuming it is the pump (any other suggestions?) My question is am I being unlucky or are pumps really going out this often. This will be the third in 5 years. Maybe it is time to buy one of the uprated ones from Nicks. Any suggestions or recomendations would be great. Right now I am at the stage where I am thinking of buying an updated radiator and pump from Nick and of course putting on another set of belts while thinks are apart.
  2. sp308qv
    sp308qv Karting
    Nov 20, 2003
    101
    South Jersey
    Steve Ponzetto
    Make sure the belt tension is correct, and try Nick's, it looks very cool!
  3. JTranfield
    Dec 29, 2003
    665
    NYC, London
    J Tranfield
    Belt tension is definately good.
  4. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    Check and make sure the pulleys are aligned properly. If not you may be bending the shaft in the water pump with the tension.
  5. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Some water pumps are VERY finicky about how they're installed. Mine has a reputation of giving about 10k miles and that's it. Well mine lasted 50k miles; here's why:
    1: Belt tension. Too much and you put a side load on the bearing. This will always lead to premature failure. Most people have no idea what the correct tension is, or how to measure it. If you can convert to a Glimmer drive, this will help (or is yours already?)
    2: Pressure. Is your radiator cap the correct PSI for your car? I know some people use a higher pressure cap because of cooling issues; this can lead to premature water pump failure.
    3: Crappy shop technique. My pump MUST be installed with the preceision of a NASA shuttle, and they fail too. It's really not a job for a careless mechanic, and I bet a Ferrari pump is no different. Everything must be perfectly aligned, and the impeller must be pressed on the shaft with a press. No banging on it! The bearing also must be pressed in. Shortcuts lead to premature failure.
    Since you've gone through so many water pumps, I suggest you get a new mechanic, or if you've done them yourself, have a Ferrari mechanic do the next one.
    Ken
  6. BigTex
    79,406
    Houston, Texas
    Bubba
    I've had rebuilt ones fail after several years......I go with a new unit if available....
    Then there's that billet one available......
    Whatever, it keeps you in practice!
    Definately use the recommended tension on the belts, I think there's even a tool.........
  7. JTranfield
    Dec 29, 2003
    665
    NYC, London
    J Tranfield
    Thanks for the replies guys. I have looked over everything and it just seems to me the exchange pump failed. Belt tension is good for sure. The only other possibilty is that is was very hot this weekend in GA the temp went higher than normal and blew the pump seal before a hose? I had just replaced the 0.9 cap with the updated 1.1 cap but doubt this was the issue. I will order the updated one and see how I get on and report back.
  8. bwassam
    bwassam Formula Junior
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    I'm in the process of getting my manifold fixed from corrosion from the antifreeze. In thinking about this corrosion, I figure that the water pump will be the next thing to go toes up. In looking at the cost of that issue, I found that Lyle Tanner sells them for $545 each. I don't know if that's a rebuild or new. Also, I don't know if that's a good price or not, but it seems about right.
    A side note, I' having the hoses that lie under the manifold changed now so that I won't have to do them later. It's one of those "While you're at it" issues.
    Bob Wassam
  9. f355spider
    f355spider F1 World Champ
    18,055
    Make sure you get the updated, large bearing water pump; and take the advice of the other posts.
  10. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    LOL, you guys....$545 for a water pump! It's $35 worth of parts in a $510 box. Tell me this is made in Modena....or is it the same as a $65 unit from elsewhere?
    Ken
  11. f355spider
    18,055
    Ken,
    I for one am a little annoyed at your constant "hand wringing" over Ferrari's weaknesses, and parts costs. We all know we are "taking it in the a s s", but so what? What does this comment do for the thread? Is there really so little action on the Lotus forums that you have to hang out here? ;)
  12. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    Your point is well taken: I'm flaying at windmills. Sooner or later I'll be one of you guys doing the same thing. I'm thinking if enough people post ways to avoid yellow boxes I'll save or buck or two, so I whine to encourage the masses.
    For the record: My TC water pump died and needed the engine removed to change it; there's an aftermarket front cover/cassette water pump deal that with installation cost me about $1600. If it dies I pay $300 for a DIY replacement; no engine removeal needed. So I'm doing the same thing!
    Ken
  13. JTranfield
    Dec 29, 2003
    665
    NYC, London
    J Tranfield
    I think an updated one is a cheaper from Superperformance in the UK. They also make that cool aluminum header tank for 308s. Right now the plan is to fit an updated pump, aluminum header tank and one of Nicks aluminum radiators. I fgure about $1800 all in all but hopefully will never have another problem like this and will have save about 35 pounds in weight.
  14. bwassam
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    Thanks. I appreciate this information. If my pump goes out, I'll go with Superperformance in the UK. Again, thanks.
    Bob Wassam
  15. f355spider
    18,055
    Okay Ken, at least you are sharing in our pain... :)
    On to more Ferrari crap parts....I'm doing a "preventive replacement" of my exhaust manifolds on my 355 this weekend. Current factory oem ones were replaced 18k miles ago, and are sure to go soon (last ones went at 16k miles), so I am installing the rebuilt QV London ones. All told this is going to set me back about $2600 in parts alone...plus all the beer, pizza, and various bribes to my Ferrari club buddies who are helping! All because Ferrari (and Ansa) put inferior manifolds on the car in the first place (and second place with the replacements!).
  16. Jdubbya
    Jdubbya The $10 Trillion Man
    43,684
    Hell's waiting room
    I got my pump from a gentleman on E-bay. I can't remember exactly but as I was doing research he was mentioned as being very good (in the old archives). He has something to do with a Jaguar shop back east. His E-bay user name is excelsiorz if you want to contact him. He was listing them pretty regularly but I don't see one there now. If my memory is correct it was just over $200 for the pump and gasket.
    As for the manifold, mine was also pitted pretty bad. I couldn't find a new one and the cheapest used on I located was $650 so I repaired mine as well.
  17. Jdubbya
    43,684
    Hell's waiting room
    See my previous post about the pump. The tank from SP is nice but make sure the fittings are correct for your car. They wouldn't work for my '78 gts. I would also think about keeping the stock radiator. If it's working properly it will keep up just fine, although an aluminum one would be lighter. I took mine in and had it pressure tested to 18lbs, held up just fine.
  18. JTranfield
    Dec 29, 2003
    665
    NYC, London
    J Tranfield
    Did you send the pump back to the UK or modify it to fit? I see they list a few different models on their site.
  19. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    WOW, that explains A LOT of the medical problems i have been experiencing since receiving the 308. ;)
  20. JTranfield
    Dec 29, 2003
    665
    NYC, London
    J Tranfield
