Another WUR Question | FerrariChat
Discussion in '308/328' started by tiredtom, Sep 20, 2012.
  1. tiredtom
    tiredtom Karting
    Feb 26, 2012
    85
    Monterey County, CA
    86 328 GTS
    Is the WUR supposed to get 12V as soon as the engine is started or after a heat sensor says the engine is warming?
  2. Steve Magnusson
    26,829
    Always +12V -- whenever the engine is cranking or running.
  3. tiredtom
    tiredtom Karting
    Feb 26, 2012
    85
    Monterey County, CA
    86 328 GTS
    Thanks. I thought so. Also, I just found an issue that is likely causing a cold start rough run problem. The female plug that goes onto the WUR is missing one of the pinch contacts on one side of one leg. So it is probably making intermittent contact. Where would I get a replacement plug?
  4. Steve Magnusson
    26,829
    Don't know what the PN is for just the female terminals, but Bosch 1287013003 is the 2-pin (connector, boot, and two female terminals) kit.
  5. tiredtom
    tiredtom Karting
    Feb 26, 2012
    85
    Monterey County, CA
    86 328 GTS
    Excellent. Thanks, Steve.
