Ansa exhaust flow | FerrariChat
Ansa exhaust flow
Discussion in '308/328' started by Steve King, Sep 26, 2008.
  1. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    OK I have gone through about 20 different search posts and have found a lot of info on fabing up replacement mufflers for the 308's but I was tring to find out what side feeds what bank. So my simple question is if you look from the rear of the car are the right exhaust tips fed from the rear (1-4 , back of the car) cyl. bank and the left tips fed from the front (cockpit 5-8) bank. This is a non-cat 77 GTB. Thanks
  2. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    I am a shade tree mechanic at best but what I would do is remove a spark plug, put my finger over the hole,turn the engine untill I felt the compression stroke, then turn the engine 3/4 turn past TDC so that the exhaust valve is open, then blow compressed air in the cylinder and listen.
    I am sure someone will have a reason why this would cause the engine to explode.
    dave
  3. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    The Ansa blends the two flows internally through baffles. But they generally flow more exhaust out one side, the left IIRC, than the right side.
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    +1; from what I have seen they are blended.
  5. BigTex
    79,406
    Houston, Texas
    Bubba
    Correct they dump into the can and "cross flow" on the ANSA so it 's not as you describe at all......
  6. Steve King
    Feb 15, 2001
    4,367
    NY
    Interesting because I have a slight lean miss in the right hand exhaust tips only so I wanted to see if it was due to 1 carb or extender. Thanks for the info. I'll just have to sort it out , it's intermittent and is more noticable after the motor is up to temp. OK I'll just need to do some fishing. Thanks
