ANTENNA MOUNT GONE | FerrariChat
ANTENNA MOUNT GONE
Discussion in '308/328' started by Kvnhpnr, Apr 19, 2024.
  1. Kvnhpnr
    Kvnhpnr Karting
    Jan 7, 2022
    59
    Pennsylvania
    Kevin Scott Hepner
    I am not sure how or when it happened but the mount for the antenna came off while I was driving and now it is missing, the antenna now just sits in the open hole. I recently had work done ate Ferrari of Philly but they did not touch that are of the car and I have msgd them to see if they could locate the piece I need. I have looked at the parts schematics from ferraripartsuk and cannot see that on any of them. I am including pics on this thread in the hopes someone would be able to help in locating that piece.
    Thank You
    View attachment 3673795 View attachment 3673796 View attachment 3673797 View attachment 3673798 View attachment 3673799
  2. Rifledriver
    37,089
    They are pretty universal. Id go to a local auto radio type of place and see if they have any that fit it. They are only supplied with new antennas so it may be easiest to buy a cheap antenna just for those parts if you are sure they will fit.
  3. dinoart
    dinoart Formula Junior
    798
    Westminster CA
    David
    Sorry to hear. It is very to steal. Someone might swap it off while youre not around. When I go to C&C or car shows I have to keep an eye on it. Might have to hunt on Ebay to find a broken one that has the same mount.
  4. MaranelloMark
    MaranelloMark Formula Junior
    438
    Bay Area, CA
    I recently stumbled across the parts for this. I didn't need them for mine since someone removed the antenna and covered the hole. I'm not sure if it was Unobtanium or somewhere else. My recollection was that is was a place in the UK. I'll check because I might have a lot of those links still open on one of my computers.
  5. Kvnhpnr
    Kvnhpnr Karting
    Jan 7, 2022
    59
    Pennsylvania
    Kevin Scott Hepner
    Since I don't listen to the radio that is what I probaly shoud have done when I got the holes filled in from the euro license plate mounting hole they drilled into the body when they originally put the plate on in Italy. Any help is greatly appreciated. I am going to get a cheap small antenna just to temporarly fill the hole.
    MaranelloMark likes this.
  6. MaranelloMark
    438
    Bay Area, CA
    I thought maybe Superformance but no dice. I't probably on my office computer and I won't see it until Monday. Most electric antennas used to come with several bushing types, so they should be widely available.
  7. Kvnhpnr
    Kvnhpnr Karting
    Jan 7, 2022
    59
    Pennsylvania
    Kevin Scott Hepner
    Thanks...I appreciate it...no rush I am going to try the cheap one and see how it works since it may or may not get hooked up and may just be cosmetic for the time being LOL
  8. MaranelloMark
    438
    Bay Area, CA
    Sure. I'm absolutely certain I saw them somewhere.
  9. MaranelloMark
    438
    Bay Area, CA
    Il Tifoso likes this.
  10. Sigmacars
    Sigmacars Formula 3
    1,218
    You can go on e bay under Car antenna parts And you find a lot of different parts just pick the one you like all round $20-25
  11. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    389
    Herts, UK
    Richard
    I found it very hard to source those pieces in black. Almost all for sale that fit are chromed. Eventually found the assembly on ebay.de. There is still a lot of Bosch Autojet aerials for sale in Germany, but quite pricey since Bosch stopped supporting the Autojet, as originally fitted to these cars.
  12. bl10
    bl10 Formula Junior
    Jun 8, 2011
    440
    Chatsworth, CA
    Barry Leavengood
    78 GTS US. Quick question about the antenna. Any one know the location of the antenna tube drain hole. Mine just drains onto the carpet. Got caught in a couple of serious thunder storms recently and of course soaked the carpet. I looked for the drain hole in the floor of the compartment, which I think if fiberglass, but couldn't locate the drain hole.
    Thanks in advance
    Barry
