Anti clockwise to undo a oil sump plug? | FerrariChat
Discussion in 'Technical Q&A' started by Rod, Mar 1, 2009.
  1. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Guys
    Just confirming... I am about to empty the oil on the 328. it is anti clockwise to undo the bottom sump plug?
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    #2 Iain, Mar 1, 2009
    Yep - its a standard thread. You will also find that if you can raise the left side of the car a bit as its draining you will get a whole load more out.
    If you are changing the filter then pack round the base of it with lots of paper towel to catch the spill & have a plastic bag handy to pop the filter straight into.
  3. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Iain..
    Thanks...
    I just need to loose 1tre of oil..... I have over filled her!!! this is the only way to do it?
  4. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    How much have you overfilled it? If its just by a litre then I wouldn't worry too much about it - indeed people often overfill 308s & 328s (especially for track use) - partially gets around the oil starvation problems that can arise on long left handers
    It'd be very difficult just to drop a litre out the sump plug I think - you'll end up with oil everywhere I guess when you try & get the plug back in.
    I suppose you could drop the lot out into a clean can & then just chuck what you want back in the top......
  5. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Iain...
    Done it! when cold the oil level was approx 8mil above the max level... I noticed that my oil pressure had also increased on the gauge... it was never more that 85psi before I overfilled.. Now it is 110psi when revs are up!
    Mind you the oil is black! If I had a oil filter I would have changed the lot!
    Just going to check it all over now! What oil filter are your using?
  6. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    High oil level and high oil pressure are not related. If your pressure reading went up it is because of different oil viscosity or an issue with the pressure sender/gauge/regulator, not because there is an extra oil in the sump.
    Low oil level and low oil pressure can be related.
  7. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Brian... I thought that too much oil in the engine would affect the pressure? anyway after draining out the excess oil and getting within the limits it seems that the pressure has returned to normal both cold and hot? ie when cold idle bang on 85psi, once hot at idle its around 50psi However when I turn on the lights all of my gauges (inc the petrol one) raise? Any ideas?
  8. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    I never change the oil without changing the filter too. Always use UFI filters because that's what they sell at the main Maranello parts place at Thorpe (which is about 3 miles from here).
    High oil level would not be the cause of increased pressure. The gauges are all electric & based on what you've said happens when you put the lights on I'd be inclined to think the high reading you got was an electrical issue.
    Sounds to me like you might have a bad earth (ground) somewhere.
    What kind of oil did you put in it?
    I.
  9. bill brooks
    bill brooks F1 Veteran
    6,045
    waynesburg,pa
    bill brooks
    lefty loosie, righty tighty.
    words to live by.
  10. GeoMetry
    GeoMetry Formula Junior
    Apr 14, 2008
    471
    Virginia
    Richard
    I can't speak to a 328 but I was able to siphon oil up through the dip stick tube on my 308 once. I inserted a length of clear plastic tubing through the dip stick tube and pumped a bit of oil out that way.
  11. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Simple!!!!
    I was just concerned that the italians had made it the other way round and did not want to damage the threads!
  12. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    #12 Rod, Mar 1, 2009
    I have just put modile 1 10-40 semi synthetic in.
    The pressure has defo came down on the gauge..
    When accelerating and taking the revs up to say 6000rpm would you expect the gauge to increase slightly from 85psi? At idle when warm it sits at the 50 mark but immediately goes to 85 when driving off..
    I Read in another thread that the voltage change could be due to the alternator or battery on its way out? with that in mind my batter goes flat in 7 days if I do not have the trickle charger on?
    Cars eh?!!!!!
  13. bill brooks
    6,045
    waynesburg,pa
    bill brooks
    i really feel the italians refrain from counterconvention.
    puccini's operas pretty much read from right-to-left.
  14. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Gauges in the dash seem to vary with the lights being on or off. I think that there is not enough ground in the instrument cluster for all of the bulbs and the available voltage potential drops when all of the little gauage lamps come on, or the ground was adequate back when the car was new, but not so much now.
    Still, oil pressure is supplied by the oil pump, regulated by the pressure relief valve to some maximum, goes through the cooler and filter and goes to the engine bearings. As long as the oil pump pickup is sucking oil and not air then the oil pressure won't be affected by how deep in oil the pickup is. Perhaps you have a leak in your pickup tube that lets the pump draw air from the crankcase above the normal oil level? If you can repeat higher oil pressure by adding a quart I would figure out what is going on. If your pump is getting oil and air, that is a very bad thing. If a 1" additional depth of oil in the sump really gives you 20psi more oil pressure you have an issue IMHO.
