Anti-turnover valve location 139568 | FerrariChat
Discussion in 'Mondial' started by masonb, Oct 19, 2018.
  1. masonb
    masonb Rookie
    Feb 23, 2014
    34
    #1 masonb, Oct 19, 2018
    Just a quick question.
    89 Mondial T
    I've had some extra fuel pressure in the tank when removing the cap lately, and wanted to check the anti-turnover valve.
    Can anyone speak to whether it is located in the engine compartment or in the wheel well?
    The car is off-site, and I wanted to plan for how long I need to get to it.
    Thanks!
  2. masonb
    masonb Rookie
    Feb 23, 2014
    34
    Answering my own question in case anyone searches for this.
    It is in the driver's side front of the engine compartment. I reached it by taking out the driver's side wheel well liner, the intake air vent on the left side, and I also removed the air intake hose for the engine inside the engine compartment. It can be done without removing the wheel, but I did use a lift. Took about an hour to remove clean and replace. Works like a charm now.
  3. JLF
    JLF Formula 3
    Sep 8, 2009
    1,705
    Thx for info. What did you clean it with ?
  4. masonb
    masonb Rookie
    Feb 23, 2014
    34
    Brake cleaner and then a little wd40 afterward.
