Antievaporation Line Removal at Gas Tank | FerrariChat
Discussion in '348/355' started by redryder, Aug 29, 2014.
  1. redryder
    redryder Karting
    May 30, 2008
    100
    usa
    george
    #1 redryder, Aug 29, 2014
    The lines(antievaporation) coming off the fuel tank are weird looking...does it take a special tool.....can someone please tell me how to remove these.
  2. sevminasyan
    sevminasyan Formula 3
    Jun 24, 2008
    1,156
    Glendale, CA
    Steve
    you need to push the top and bottom (squiz it) and the sides will longate making the removal easy. But, your finger wont fit the top of the line since the rear lid strut or something else is in its way. use a flat head screwdriver to push down from the top, finger to push up the bottom and pull it out. the line is pointed upwards so it makes it hard. I would lower the gas tank a bit if needed.
    hope I helped more that put you in panic mode :)
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,573
    San Carlos, CA
    Mitchell Le
    Squeeze and pull
